Transmission & Drivetrain Gearboxes, Differentials, Clutches
2 Transmition questions
Old Mar 11, 2013 | 08:31 AM
ReillyEK's Avatar
Default 2 Transmition questions
Hey guys I have a sir sc4 tranny and was looking to change out the oil on it. I have a the normal 3rd gear grind at high rpm and my first question is what's the best oil to use / change out. It is my dd and it's bolted up to a b20
Seconds question ...... 5th gear highway driving is nuts 120km/h @ just over 4000 rpm. So is ls 5th gear and option ? If so what does it take to make that happen
Thanks
Old Mar 12, 2013 | 06:42 AM
Aquafina's Avatar
Default Re: 2 Transmition questions
Changing out 5th gear will get you an RPM drop/jump that you won't like, the inability to stay in 5th all the time, and likely worse mileage.
As for fluid, you need to have the transmission repaired now. Fluid will not fix it and if not repaired now, it will cost more to repair later. That said, use non-synthetic 10w-30, Torco MTF, or Torco RTF.
Old Mar 12, 2013 | 09:02 AM
ReillyEK's Avatar
Really? I thought ls 5th would be better for highway driving because I wouldn't be reving so high.... I looked up what my transmission calls for , just Honda mtf would torco be better ?
Old Mar 12, 2013 | 09:45 AM
kyden's Avatar
an ls 5th gear with a b20 won't be bad on the highway, but the rpm drop from 4th to 5th would be very dramatic.
Old Mar 12, 2013 | 01:14 PM
Aquafina's Avatar
The only time I recommend Honda MTF is if the car is only driven by a very mild mannered grandmother and will never see the rev limit or any power.
Old Mar 12, 2013 | 01:33 PM
Fliptard's Avatar
just because you have an LS 5th doesn't mean it's going to drop alot. You have to take into consideration what Final Drive you have as well.
Old Mar 12, 2013 | 04:27 PM
94EG8's Avatar
Seagull Management
Aquafina knows that, he builds these things daily.
Old Mar 12, 2013 | 04:37 PM
ReillyEK's Avatar
I did read into torco mtf and so far I thinking that is best I live just outside of Toronto, where would it be sold? Or do I gota order online ?
It's a sir tranny 4.4 final drive but I would probably end up being **** on highway runs now performance wise ? Ls fifth is a thought because 45 minutes straight to work everyday @4300 rpm in a complete gutted car and striaght pipe at 530am can sometime be a little annoying lol
Old Mar 13, 2013 | 06:54 AM
Aquafina's Avatar
FD does not affect RPM drop.
I would do a 50/50 mix of MTF/RTF or straight RTF since you live in a colder climate. MTF can be a bit notchy when cold.
Old Mar 13, 2013 | 09:52 AM
ReillyEK's Avatar
Ok so where do I buy some ?
Old Mar 13, 2013 | 11:26 AM
Aquafina's Avatar
You'll need to find a dealer in Canada. Due to shipping restrictions US dealers cannot ship it across the border.
Old Mar 13, 2013 | 11:42 AM
accorse07's Avatar
try amazon...price is not great but im pretty sure amazon could get it shipped.
kevinm1981
31
Aug 2, 2011 10:02 AM
igotboost
Jul 10, 2006 03:36 PM
Forrest Gump 9
Aug 21, 2003 09:55 AM
typeSwarrior
May 29, 2003 03:51 PM
chuteBOXE
Apr 13, 2003 02:34 PM
