Not Again!! Engine Code 7
Alright so about 5 months ago i replacd my tps sensor cause it was throwing the code 7, well guess what.. ITS BACK AGAIN. keep in mind i took one off a old engine, but jeez my luck
any other ways to fix it other then replacing it again??
thanks
oh yah i drive a 1988 honda crx dx 5spd
thanks
thanks
thanks
Tune it with a multimeter. Probe the middle wire (red) and ground your other lead. Loosen the screws so you can twist it. With the throttle closed twist the sensor untli you get as close to .5 volts as possible. Tighten screws and recheck. Resent ECU. Code should disappear. HTH
scarney
Sep 9, 2012 02:37 PM
rudyndrew
Dec 30, 2010 02:12 PM
briangela
Nov 6, 2002 10:14 AM
