Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Lighter flywheel
Old Mar 10, 2013 | 06:32 PM
gagedally's Avatar
Icon2 Lighter flywheel
I want a lighter flywheel in my 01 Civic, but don't know what to get. It will be my daily driver, but I still want it to get up and go. What should I get?
Old Mar 10, 2013 | 07:41 PM
toyomatt84's Avatar
Sanji
Default Re: Lighter flywheel
Changing the flywheel really won't net you much besides a slightly quicker throttle response. Its really not going to make the car much quicker at all.
Old Mar 10, 2013 | 11:56 PM
EM2abe's Avatar
^ this is true. you'll notice a only a slightly quicker rev when the car is in gear. it will also rev quicker when shifting up/down. but you dont want to ruin your synchros.... $$$
Old Mar 11, 2013 | 03:43 PM
gagedally's Avatar
Yeah, I wasn't expecting it to net me any more speed. What kind of brands should I buy? I'm pulling the tranny out Friday for a rebuild and want to install everything at the same time.
Old Mar 11, 2013 | 05:59 PM
EM2abe's Avatar
well, i personally did a ton of research before getting mine. the main flywheels that you would be looking at would be made by exedy, fidanza, bisimoto, and competition clutch i think. i ended up going with exedy because its made of steel. the face of the fidanza flywheel is aluminum and even though it was cheaper, i know it wont last as long as the steel exedy. i didnt go with the bisimoto or competition clutch flywheels because they werent as reputable as exedy. when you pull the old one out, you will definitely FEEL the difference. LASTLY if you are planning on replacing the flywheel, you should also think about replacing the clutch kit as well. just so that you have two NEW surfaces to mate with each other.
Old Mar 11, 2013 | 09:38 PM
gagedally's Avatar
Yeah, I saw the Exedy one. I was also planning on getting a Kevlar clutch. My mentor, who is helping me with my senior project, said I shouldn't get a 6 puck or anything.
Old Mar 11, 2013 | 10:50 PM
EM2abe's Avatar
the kevlar isnt worth it, in the end. yes it stands up to heat better, and yeas it will be a little lighter and more durable. but its just too much for a stock motor. also, if it ever over heats, then you're pretty much screwed. the surface of the disc will never recover if subjected to too high of a temperature.
Old Mar 12, 2013 | 04:03 PM
MUGENVX9's Avatar
http://dezod.com/
Emorales
Oct 7, 2009 07:14 AM
jelatime
Oct 4, 2009 02:42 PM
Fresno_NSX
Mar 15, 2005 09:26 PM
mild98
16
Sep 7, 2003 07:59 AM
FORTIS
Feb 12, 2002 08:52 AM
