white spark plugs d15b1 running lean
Old Mar 10, 2013 | 05:31 PM
egefcivicguy's Avatar
Default white spark plugs d15b1 running lean
Ok I was checking the compression on my dpfi d15b1 and got 220 220 225 and 220, is this normal? While I had the spark plugs out I noticed the tips were dry and white. What can I do to correct this? I don't want the motor to destroy itself.
Old Mar 12, 2013 | 03:55 PM
ef_cowboy's Avatar
Default Re: white spark plugs d15b1 running lean
You have high compression. And you plugs sound like normal wear
Old Mar 12, 2013 | 04:30 PM
BIGef's Avatar
damn thats high comp motor
Old Mar 14, 2013 | 04:09 AM
crxin's Avatar
that compression is super high, and your plugs should be a golden brown not white. White in fact means you are running lean.
How old are the plugs? How long have they been in there?
Have you checked your fuel pressure?
Any check engine lights?
axionm1k
Jul 17, 2008 05:02 PM
elikas
Jan 18, 2007 07:40 PM
VtecDA9
Dec 10, 2003 05:26 PM
euclid
Jun 20, 2003 02:33 PM
sporkcrx
Nov 12, 2002 05:56 PM
