Trying to figure out what b20 I have
Hey guys I just read https://honda-tech.com/forums/all-motor-naturally-aspirated-44/b20-non-vtec-faq-guide-including-p8r-head-information-1467903/ but I'm not to sure how to tell what exactly what one it is I just checked it out it's a p75-7 and it was made is 99 I'm pretty sure so what motor is it ?
B20B / B20Z
* 1999 - 2001 specs
* NON-VTEC
* Found in: USDM CRV as a B20Z, JDM Honda CR-V and Honda Orthia as a B20B
* Displacement: 1,973 cc (120.4 cu in)
* Power: 146 hp (109 kW)) @ 5400 rpm
* Torque: 133 ft·lbf (180 N·m) @ 4300 rpm
* Rod length: 137 mm (5.394 in)
* Compression: 9.6:1
* Bore: 84 mm (3.3 in)
* Stroke: 89 mm (3.5 in)
* Redline: 6300 rpm
I'm thinking it's this one but I could be wrong
* 1999 - 2001 specs
* NON-VTEC
* Redline: 6300 rpm
does it have a knock sensor if so its the 9.6:1 compression motor should be a brown sensor on back of the block i believe if not its th 9.2:1
MrMug3n
Apr 9, 2008 02:56 PM
