94 accord under hood o2 sensor
Old Mar 10, 2013 | 08:53 AM
VooDooDolKiller's Avatar
Icon6 94 accord under hood o2 sensor
I have a 94 accord and the o2 sensor under the hood is not pluged up. The o2 sensor is in the motor and the wires has been clipped off. My ? is were is the plug that goes into the o2 so i can replace it. I have looked and cant find it no were.
Old Mar 10, 2013 | 09:53 AM
holmesnmanny's Avatar
Default Re: 94 accord under hood o2 sensor
It's going to depend on exactly what kind of car you have.
Old Mar 10, 2013 | 09:58 AM
I hav a 94 accord ex 2.2L vtech
Old Mar 10, 2013 | 10:14 AM
Your oxygen sensor is in the downpipe. You will need to jack up the car and put it on stands then slide underneath to access it. You will see it just before the catalytic converter.
How is it that you can see it but still do not know where the plug is ?
92 civic ex 4dr's Avatar
So the sensor is not plugged in. The wires to it are cut off. From the harness or the sensor?
Btw an o2 sensor does not go into the engine, it goes into the exhaust.
Posted from Honda-tech.com App for Android
Old Mar 10, 2013 | 10:28 AM
There is on right up udoor the hood and one in the back of the car. The one undoor the hood has the wires cut on the o2 senor the senor is still in the hole and the wires are cut on it and I can't find the plug
Old Mar 10, 2013 | 10:40 AM
If you have the lx model your only oxygen sensor would be in the exhaust manifold in the front of the car. If you have the ex model it will be in the downpipe. You only have one oxygen sensor.
The only way you would have two sensors is if your car was a '96 or '97.
Old Mar 10, 2013 | 10:44 AM
Old Mar 10, 2013 | 10:49 AM
GhostAccord's Avatar
Do you also have an O2 sensor in the exhaust under the engine that is plugged in? If you do, I think someone has replaced your stock exhaust with one from a 96-97 and used a junk O2 to plug the upstream O2 bung.
If you have the down stream O2 sensor wired up you do not need this one wired up as well on an OBD1 chassis.
Can you take a picture of the valve cover and one of the engine stamp ?
Markadler47@gma
Mar 22, 2019 02:36 PM
Nataku
Jul 3, 2008 09:44 PM
novtecnoboost
Feb 11, 2007 06:56 PM
coolrahool
Aug 23, 2006 05:09 PM
