B&M fuel reg.
Old Oct 21, 2002 | 08:38 PM
FitCRX's Avatar
Default B&M fuel reg.
How in the hell do you put this thing on...it says you use your stock. I understand where it is suppose to go..but I don't know how to take apart my stock regulator.
I see how the regulator is two peices..and I need to use the bottom half...but how to get it apart?
Old Oct 21, 2002 | 08:40 PM
InevitableRace's Avatar
Default Re: B&M fuel reg. (FitCRX)
Why dont you read the directions??..That always works for ME......
Old Oct 21, 2002 | 08:52 PM
FitCRX's Avatar
Default Re: B&M fuel reg. (allmotrb18c1)
all you had to say was hacksaw it off!
Thanks
Old Oct 21, 2002 | 08:53 PM
stupidfast's Avatar
speaking of b&m regulators.. when i adjust mine past 48psi it just sticks there.. it doesnt drop back down like its supposed to when im not on the throttle.. What the hells up with that.. Any guesses??
Old Oct 21, 2002 | 09:04 PM
FitCRX's Avatar
Default Re: B&M fuel reg. (stupidfast69)
from what I understand...fuel pressure doesn't change...shouldn't matter weither your at idle or WOT. Correct me if Im wrong
Old Oct 21, 2002 | 09:19 PM
tonyxcom's Avatar
It does change, with vacuum pressure. Hence the little vacuum hose.
Old Oct 21, 2002 | 09:59 PM
3rdGteg's Avatar
Default Re: B&M fuel reg. (tonyxcom)
http://www.c-speedracing.com/howto/a...stablefpr.html
step by step with pictures.
Teamdiesel
11
Nov 11, 2007 05:39 PM
MikeNice
May 16, 2006 04:42 AM
mengy007
Sep 2, 2004 11:38 AM
bigfatkrakr
Jan 27, 2004 08:24 PM
