NEED HELP WIRING B18B1 INTO 89 Si
Old Mar 9, 2013 | 08:52 PM
xNOPEYx's Avatar
Default NEED HELP WIRING B18B1 INTO 89 Si
I have a multitude of problems, as it sits right now. The motor and tranny are in the car, I don't know if everything is there or if its hooked up. And the wheels and shocks are in the car, so that when they moved it, the engine and tranny wouldn't fall out and that it would roll.
after I know what is in the car, I have to rewire everything back so I can get the car running again. but its my first time wiring a car, so I've looked and looked and I cant find a very good DIY wiring diagram/directions on how to wire a B18b into and 1989 Civic Si.
I need some advice on what I should first?
also, ill be providing pictures of the car as soon as I can. ill be taking pictures of the engine bay, and everything about the car. so that you guys know what I have to deal with.
Old Mar 9, 2013 | 10:26 PM
F22Master's Avatar
Default Re: NEED HELP WIRING B18B1 INTO 89 Si
Get the stock 89 Si engine wire harness. Everything should hook up except the Oxygen sensor and the distributor.
Get an obd0 to obd1 conversion harness. It will have provisions for the oxygen sensor.
Get a distributor adaptor harness, or get the correct plug for the dizzy and rewire with your engine harness.
Done.
This has been answered for you before. Multiple times. Read. Search. Read some more. Think. And if you still have questions, search more.
Old Mar 10, 2013 | 05:27 AM
TheOdditie's Avatar
Check your other thread....
Pinner13
Jan 29, 2012 04:36 PM
Eyes Only
Aug 26, 2008 01:20 PM
sirhavok
Apr 23, 2007 09:13 AM
BR
20
Aug 25, 2004 01:05 PM
hondaeg5
Dec 19, 2003 03:46 AM
