oil sludge in coolant reservoir, no coolant in oil.
Old Mar 9, 2013 | 07:12 PM
RoseFuneral's Avatar
Default oil sludge in coolant reservoir, no coolant in oil.
so ive been having disappearing oil the last couple weeks, i thought it just started burning it.. was pissed. kept having to add oil because it kept getting low on the stick.
drove for 2 weeks, 500 miles or so.
went to change my oil, drained it all out, looked fine, black as night, changed the filter also, lowered the car, put new mobile1 5w-40 in
then i went to check the coolant, i do this every month or so, and i was shocked when i opened the reservoir...
black oil sludge.. horrible. same thing under the radiator cap..
but there is no coolant in the oil. looks good.
so i did a compression test.. its 190,190,180,190.
pretty damn good for 250k miles!!
engine is a d16z6. its a 93 civic si.
here are pics
Old Mar 9, 2013 | 07:19 PM
B_Swapped93's Avatar
Default Re: oil sludge in coolant reservoir, no coolant in oil.
Do a coolant flush(remember to bleed) and clean the rad cap+res and see if it starts again. First instinct i would say bad HG ?
Old Mar 9, 2013 | 07:21 PM
i did one after i bought the car. the coolant was perfectly green, i got the car a few months ago, but only started driving it 2 weeks ago because i was fixing things on it.
im thinking head gasket too but wasnt sure, because i would think the coolant would get into the oil also?
Old Mar 9, 2013 | 07:26 PM
Have you done a leakdown test ? are there any other signs the HG is blown ? no coolant in the oil right. Try googling you'r problem I found several posts on here with the same issue as you.
Old Mar 9, 2013 | 07:27 PM
jbpnoman's Avatar
No. It's easily possible for it to go one way and not the other.
Old Mar 9, 2013 | 07:29 PM
what all would i need to do for a leakdown test?
i did a compression test and it was very good on all cylinders. as stated in the OP.
and yes, there is only oil in the cooling system. a **** load of it.
but no coolant mixing with the oil in the crankcase/oilpan.
tried google, didnt give too much info because my problem isnt really typical of a head gasket
Old Mar 9, 2013 | 07:31 PM
it is? well i didnt know that. usually its both. so i guess im probably screwed and have to take the head off and replace the gasket. correct?
very odd because the car runs great.
Old Mar 9, 2013 | 07:35 PM
You'd need a leakdown test kit(80.00 or so IIRC) look in the FAQ's you'll find a DIY/write up on how.
Old Mar 9, 2013 | 07:56 PM
checked the FAQ's and found it. but i dont have an extra $80 to spend. i can either buy a head gasket and head studs, or a leak down tester.
but im pretty sure its the head gasket.
Old Mar 9, 2013 | 07:59 PM
You don't need new head studs. old ones should be just fine
Old Mar 9, 2013 | 08:01 PM
you sure? this engine has never been tore into before. i always see people say on here that you also need to replace the studs. could be wrong tho.
Old Mar 9, 2013 | 08:07 PM
That's all the more reason to keep the ones you have. Now if you were "building" you'r engine then i could see that, but not if you'r just taking off the head to replace the HG. save some $
Old Mar 9, 2013 | 08:22 PM
yeah true. but i will be building this engine in june. so 3 months away.
if i have the cash ill pick up some arp head studs along with the gasket too.
if not, il just use the old ones to get me by til june i think.
Old Mar 9, 2013 | 09:25 PM
Might as well, don't know if a swap is in you'r budget range. But consider it before you sink money into a d-series
Old Mar 9, 2013 | 09:43 PM
well, i cant find any decent swaps where i live. not many honda guys here.
but the goal is to build the d-series for boost. strong bottom end and head studs.
oranginal
Mar 30, 2009 07:39 AM
hAtChBaCkFoReVeR
Nov 12, 2008 12:01 PM
welfarepc
Jan 10, 2007 10:26 AM
ealex
Mar 2, 2005 09:53 AM
hybridb18
Aug 6, 2003 09:00 PM
