aem v1 1040 and k20 swap?
Old Mar 9, 2013 | 05:03 PM
bigG's Avatar
Default aem v1 1040 and k20 swap?
just wondering if it can be done i do believe the 1040 has 5 coil drivers so should be able to run the k20 swap with the oem senors
Old Mar 13, 2013 | 09:43 AM
accorse07's Avatar
Default Re: aem v1 1040 and k20 swap?
You would have to do a bunch of wiring and pinning but yes it could work. Jumpers within the 1040 box will also need to be changed to accept the new trigger.
Old Mar 14, 2013 | 04:21 AM
bigG's Avatar
Ok thanks for the info
Old Mar 14, 2013 | 07:57 AM
a1320addict's Avatar
The 1040 has enough ignition drivers as you said, my question would be are you still on VTC? If so, you'd need to utilize (3) Timing Inputs. I know the setup wizard has the trigger patterns pre-configured for a K20/K24, but I don't know if you can configure the input and function for each.
Tomsidle
K Series
Mar 8, 2019 11:46 AM
diversity210
35
Jun 13, 2010 07:07 AM
h22 civic
Engine Management and Tuning
12
Feb 2, 2010 04:37 PM
JJ's civic
Nov 8, 2008 12:51 PM
EK45VTi
May 1, 2004 11:37 AM
