B18C IM Question.
Old Mar 9, 2013 | 02:10 PM
jimmysxxl's Avatar
Default B18C IM Question.
Hi guys i am in a dillema and i wanted an opinion from people with much more experience.
My build :
B16A1 Head ( Slight Port Job, Hand Lapped Valves )
GSR Block
Stock Rods/Bolts
PCT 81mm Pistons
JDM 4-1 Header (Dented)
Blox C's ( Jun 3 Knock offs )
Blox VT
3" Intake w Vstack
PR3 Intake Manifold
B16a1 stock TB (58mm)
Here comes my confusion, last month i had it tuned and layed down 220 crank hp at 8900, torque was a bloody straight line till the redline, we didnt try and see where it would drop off but my tuner told me that the engine will make more power way above 9000 judging from the Fuel/Ign maps. I dont want to rev it higher at this point with stock rods/bolts but i DO need a bigger TB/Intake Manifold. I do have a P30 Intake manifold that i was planning on porting and using with an 70mm TB. Do you guys think that i will benefit more from an ITR style intake manifold given the 8900 redline than a P30im/70mmtb combo ? Thanks a lot for your help !
Old Mar 9, 2013 | 03:31 PM
vtec8200's Avatar
Default Re: B18C IM Question.
The ITR manifold will fit your motor better than the p30 since you are 1.8L and not stock.
Old Mar 10, 2013 | 04:36 AM
jimmysxxl's Avatar
that's a generality. If the ITR style IM doesnt provide significant gains until 8900 and it just makes the engine hold power longer it won't be any use since i already dont see power dropping off anywhere. Anyone used Jun3/Blox C (0,0) and made power above 9000 ?
nikanoras
18
Feb 17, 2010 06:31 AM
djviet2000
Apr 20, 2008 07:37 AM
si0385.
Feb 5, 2007 02:58 PM
Speedra500
Feb 10, 2004 02:10 AM
tylerdurden
Jan 30, 2003 05:46 PM
