95 Civic Coupe z6 electrical gremlin
Old Mar 9, 2013 | 01:17 PM
Crazed_T's Avatar
Default 95 Civic Coupe z6 electrical gremlin
So here's the story -
I have a 95 coupe, d16z6 vtec engine 5 speed manual. In the coldest mornings it starts fine, no issues. But say I start it, warm it up, and stop to get gas, if I shut the car off it will not start. Sometimes it takes 35-45 minutes before it will even try. You can smell fuel when it's cranking, which would indicate no spark. So I bought a new disty, to no avail. I got to searching around on here and stumbled upon the main relay issue. I thought "Oh joy, it will be fixed!!!" Well i bought a brand new main relay, still being a little ****. All of the grounds look to be well grounded and in place. The wiring harness is not hacked up either. What in god's name is wrong with my little green coupe?
Old Mar 9, 2013 | 01:26 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 95 Civic Coupe z6 electrical gremlin
Is this just a continuation of this post?
Originally Posted by Crazed_T
So I drained the coolant, opened the bleeder, and refilled coolant. Tried a different IAC, now it will only start when I unplug the vac hose going to the canister from that little sensor on the drivers side of the intake manifold. Could the cannister be an issue? I feel like it's vacuum related but not sure how to approach it from here.
Old Mar 9, 2013 | 01:34 PM
Crazed_T's Avatar
Yes and no, It cleared up for a while.
Old Mar 9, 2013 | 01:38 PM
The Grumpiest
SO how did it become an electrical issue?
Old Mar 9, 2013 | 03:12 PM
Crazed_T's Avatar
Little update - I went out to the garage and cleaned up all the grounds. Still no start when warm. Could a ECU cause this issue? Everything listed for this type of problem I have replaced or fixed, from what I could find. I can smell raw fuel after cranking then when it finally catches some fire, it kind of stumbles and wants to die out.
Old Mar 9, 2013 | 06:52 PM
Crazed_T's Avatar
I think it was always an electrical issue, just freak chance it happened that way.
Old Mar 9, 2013 | 11:39 PM
eghatch9295's Avatar
Stancetard Hate Monger
sounds like your coil took a dump. common problem, common symptom is them not cooperating hot.
Old Mar 9, 2013 | 11:55 PM
Marvin1985's Avatar
I have a coil if you need one just pm me. But you said you replaced the dizzy so unsure that's the issue. You should just pay $80 to the dealer to diagnose it before you buy something more expensive
Old Mar 10, 2013 | 08:41 AM
Crazed_T's Avatar
z6 has internal coil distributor. Brand new disty, how could the coil be bad?
Old Mar 10, 2013 | 08:55 AM
joey56223's Avatar
to me it sounds like you have a fuel issue not an electrical issue!! it starts cold because the plugs dry up over time, then you drive it causing it to run rich and the plugs get saturated, then you go to start and it wont because its got fouled plugs(happens to be warm at this time) you need to look into your injectors/fuel pressure regulator/ etc!! i would start there, especially if you are smelling fuel.....you should never smell fuel
Old Mar 11, 2013 | 02:10 PM
Crazed_T's Avatar
So I got outta work today after putting on a known good FPR, it ran fine at lunch and i left it idle my whole lunch break. When I got in to leave it fired like twice, then wouldnt start for an hour. When it started smoke was flying from exhaust (white) and it stuttered when i reved it up. It acted like it wanted to die out if I didnt hold the throttle. So loading up fuel. What do I need to replace?
Old Mar 11, 2013 | 03:48 PM
lazlong's Avatar
Check compression because it sounds like a bad head gasket.
Old Mar 11, 2013 | 04:46 PM
Crazed_T's Avatar
It turned out to be a coolant temp sensor.
Old Mar 11, 2013 | 05:00 PM
lazlong's Avatar
Good to know. Makes sense since the issue is temp related.
krishblake
20
Dec 11, 2016 07:05 AM
NickLamb
Mar 25, 2013 08:42 AM
Blaze45
Dec 15, 2011 02:37 PM
TurboBumblBee
22
Apr 23, 2003 07:07 AM
