86 crx hf
Hey guys my name is darin. I'm having some trouble with my rex. For starters it will crank but only run for a second. If I hit the gas pedal it dies instantly.I removed the filter box from the top of the carb,then proceeded to check the inline filter next to the carb.it seemed old so I removed it and ran a fuel line [no filter) straight to the carb.it seemed to crank with less effort.so I replaced both filters,the lines and pump. Problem still persisted....I noticed a screw on top of the carb, kindly turned it and the car ideled out perfect on its own..I let it run about 20 min to get her flowing good, when itt cooled down iput it backtogether now its back to cranking for a sec an dien.I'm new to carb hondas.any info would help a lot.thanx guys
smokenmirrors
May 16, 2010 10:11 PM
CoolRedXylophone
Apr 16, 2006 04:13 PM
