1990 Window Regulator on a 1989 CRX PLEASE HELP
Hey Team,
need some help here. i have a 89 CRX Si and got a 90 CRX is Window Regulator. everything looks the same but the Window Bar.
Question:
-how do remove that window bar ( the bar that holds up the window )?
-do i need to drill out something?
-can i just cut off the extra hole that made for the 90 crx off and just use the 90 window bar?
thanks everyone
Question:
thanks everyone
ALL 89-91 crx SI AND DX + 90-91 HF (Door mounted seat belts) shares the same door panels/window/regulator WHOLE DOOR assembly.
ALL 88 CRX SI/DX/HF + 89 HF (pillar mounted seat belts Share the same door panels/window/regulator WHOLE DOOR assembly.
Basically Any CRX, NOT CIVIC, door mounted seat belts you find will bolt up to your existing door mounted seat belt'd door. and vice versa.
