H22 rod bearing oil clearance: .038~.051mm ok?
Old Mar 7, 2013 | 08:41 PM
jdm_rb20's Avatar
Default H22 rod bearing oil clearance: .038~.051mm ok?
I have the giant pdf prelude Factory service manual, and I see that it is under the "service limit", but I am doing this solo and it is my first engine rebuild. I am just looking for a "nod of approval."
Using Green plastigage, I have rod bearing oil clearance result ranging from .038mm to about .045mm. Can someone give me the confirmation that I am doing well so far? I already have to order some replacement bearings because of an improperly installed piston ring causing resistance (rookie mistake)....if I have to order a whole dang set of new bearings, just to get one pair, I atleast want to see if I should order a different size....
I'll plastigage the main bearings tomorrow and post results for your approval. Thanks in advance for supervising a rookie. :D
Old Mar 7, 2013 | 10:53 PM
h24 eg's Avatar
Default Re: H22 rod bearing oil clearance: .038~.051mm ok?
Have you checked the oil pump? What engine oil to use?
Old Mar 7, 2013 | 11:36 PM
92civiceg9gsr's Avatar
In inches thats ~ 0.0015" - 0.0018" IIRC. Which is in the middle of the OEM specs. You'll be fine.
Old Mar 8, 2013 | 04:07 AM
jdm_rb20's Avatar
Thanks!! Like I said, I am just nervous because I ordered standard size fittings instead of "chart-specific" OEM sizes and I'm a rookie.
H24_eg, huh? I havent gotten that far yet..why do you ask?
Old Mar 9, 2013 | 06:16 PM
98vtec's Avatar
moderator emeritus
You didnt say the rods you are using or the intentions of this engine.
If its a stock rebuild revved to stock limit then yes its fine
Old Mar 10, 2013 | 12:29 AM
h24 eg's Avatar
I was always confused in this hybrid, the presence of holes in the rod f22 for cooling the piston.
I would use bearings without hole for oil! Because in block H22 already has oil jets!
Why did you change the bearings? Maybe you need to replace the oil pump or install the oil pressure sensor
Old Mar 10, 2013 | 04:38 PM
jdm_rb20's Avatar
I replaced the bearings because I spun a bearing in the stock h22 (with stock internals). I decided to put in the f22 internals from a f22 engine I had in the shop.
I haven't been able to plastigage the crank yet because: double shifts at work, had to "rescue" my wife on her roadtrip Friday, and been rebuilding her broken brakes in between my shifts at work. I did order the complete set of new pistons rings (even though I only need 1 cylinder), so I will have extra rings..lol I am waiting to order bearings until I have more time to plastigage rods again to re-confirm my original test....this time I will also be plastigaging the crank so I will be able to check rod-plastigage with the crank torqued also. Should be no difference?
Old Mar 10, 2013 | 04:44 PM
jdm_rb20's Avatar
It is:
H22a1 block
F22 crank
F22 rods
H22a1 pistons
H22A cams
Skunk2 Intake manifold & throttle body
generic header & exhaust
Purpose: daily driver = soft launch @ redlights, then moderate-heavy throttle driving
goal: reliable, fast, fun :D
Old Mar 10, 2013 | 05:54 PM
98vtec's Avatar
moderator emeritus
If you want it to last, keep it under 8000. Any higher and you will need to open up the mains and most definitely the rods to compensate for the higher rpm clearance requirements it is going to want.
Old Mar 10, 2013 | 09:01 PM
jdm_rb20's Avatar
I baby redlines. Probably shift at 7000rpm. Should be fine for that?
Old Mar 10, 2013 | 09:08 PM
Spawne32's Avatar
If would be fine for that and then some, no reason to open it up anymore. The loosey goosy standard that everyone uses Ive always seen causing more harm then good. I like my clearances to be around the middle to loose end of the OEM spec. That way you dont have to run a diesel weight oil to get oil pressure, and run the risk of wiping your cam's and valvetrain out from running too thick of an oil to make up for your throwing a hot dog down a hallway main/rod bearing clearances. Piston ring and P2W clearances are another story entirely.
Old Mar 10, 2013 | 10:07 PM
jdm_rb20's Avatar
Because I am a rookie, I just want to make sure I understand correctly. This is my understanding of what you said:
You like your clearances to be "med~loose" ....so you don't have to run thicker oil ...making up for extremely loose clearances?
This makes sense, I just want to make sure I absorbed the info correctly. Summary: Make sure they aren't too loose....medium is best??
Old Mar 10, 2013 | 10:29 PM
Spawne32's Avatar
"race motors" if you will, like alot of builds you will see on the forum, run outside of what we call the "service limit". There is a range of acceptable tolerances, and then there is the service limit, which is the maximum limit to your clearances honda will ever allow on their engines. Personally I see no reason to run this far outside of the range of clearances that honda provides as "acceptable". I think the risk of spinning a rod bearing increases substantially when you try to push it this far. Most of the time its done by running a thinner bearing, which cannot handle the stress of a high hp motor in my opinion, thus making it more prone to failure.
If you want the extra oil cushion that looser bearing tolerances provide, I think the best option you can have is having the crank chamfered on the rod journals which aids in oiling under high load. No reason to have this done on the mains though, as the bearings arent designed to take advantage of this on our main journals because of their shape.
Old Mar 10, 2013 | 10:31 PM
Spawne32's Avatar
And to clarify, the reason why the looser clearances were adopted in racing situations is because it is believed that the increase in oil film between the bearing in the journal reduces the chance of wiping a bearing. However you need to make up this difference by running a thicker weight for oil pressure. (which also adds to oil durability) However your cam journal clearances have not changed....thus the weight of the oil is too thick for the cam journals clearances.
Old Mar 11, 2013 | 05:28 AM
98vtec's Avatar
moderator emeritus
just know that material use and rpm (and HP in clearancing other parts) play a vital role in "building" an engine and not just assembling one to honda specs and calling it good. Honda spec isn't the key when it comes to building an engine with forged internals and revving beyond factory rev limiter. They help as a reference but i wouldnt use them as my specs in most cases.
Since you are going to be short shifting the engine, those specs on the rods will be fine and dandy. Just be sure the mains are good and "straight".
since this is a learning experience, measure everything you can with what you have available. a set of feeler gauges can do both your crank and rod end play as well as your ring gaps.
Old Mar 11, 2013 | 05:03 PM
jdm_rb20's Avatar
Haha...the FSM is starting to remind me of Pirates of the Carribean. "See, the Code is not really a Code...it's more like a set of guidelines." :D
And yeah, I learned how to use my feeler gauges to check ring gap, etc.
Old Mar 12, 2013 | 08:37 PM
jdm_rb20's Avatar
Good news!! Double checked the rod bearing clearance with plastigage and got the same acceptable results, so I feel like I did them right. I also finally plastigaged the mains and they are a tad tighter: .025mm~.038mm. I'm hoping that is also good?? I think I am finally ready to finish building this motor :D
Old Mar 13, 2013 | 02:18 AM
.025mm is ~ .001". That's a little too tight there. Swap the loosest main bearing pair with the tightest pair. Recheck your measurements and see if they improve.
Old Mar 13, 2013 | 03:51 AM
jdm_rb20's Avatar
It's a little looser than oem spec. They are between .025 and .038mm. I'd estimate about .034" average.
Old Mar 13, 2013 | 01:58 PM
EG1834's Avatar
That's pretty tight for the mains. I run roughly .001" per 1" of journal diameter for most performance oriented engines, even more for the more hardcore stuff. The aluminum blocks tend to expand a lot, so in endurance racing you have to take that into consideration too. Oil pressure suffers, sure, but oil pressure doesn't really do anything.
I would like to at least see .0015" for the mains and rods if its a low rpm street car.
Old Mar 13, 2013 | 06:53 PM
.034mm is like .0013" which will work its just kinda tight. Are all the mains the same measurement? If not swap the loosest pair of bearings halfs for the tightest like is said before to try and even out the measurements.
SCR ZC-T
Mar 6, 2012 01:30 PM
turbociv
15
Mar 11, 2004 01:16 PM
PSI-spec
Feb 16, 2003 07:18 PM
HotWheelz
Nov 2, 2002 10:01 AM
dustin
Oct 23, 2002 12:06 PM
