JDM ITR 5-lug VS USDM ITR 5-lug Front Hub any differences
hey guys heres the deal i have JDM ITR 5lug 36mm on my integra with a k20 motor swap trying to use stock rsx type s axle but they wont go into the spline of the hub idk i tryed everthing so i was wondering if i was to switch the hub to the usdm itr 32mm hub part number 44600-ST7-R00 would it be problems like are they the same size as the jdm ones ?
Well if you do in fact have the JDM 36mm set up then your RSX-S axles should work as they are 36mm also...I have the USDM set up so I had to use base model(32mm) RSX axles...
Well he is having a problem with 32 I'm having a problem with 36 I just want to know if the USDM is the same size as JDM
USDM ITR - 32MM
JDM ITR - 36MM
I would assume that the RSX-S axles would work with your setup but if they're not fitting inside the hubs...idk man.
JDM ITR - 36MM
FRKWOO
Jan 15, 2011 06:47 PM
hoamic11
Mar 13, 2005 07:06 PM
