grounding my wires
I never said thicker ground wires would hurt. He said he already upgraded them. I simply said there's no reason to run the new wires than how the old wires were.
There is a certain point where your wire can be too large, but I don't think anyone's actually interested in the electromechanics behind it. Suffice to say, don't bother going higher than 4g small-wound wire. Definitely don't use large-wound wire - you'll only end up hating life.
Nope, just run them the same way the stock wires are run. Ultimately, they already are linked together. Your battery ground runs to the chassis, as do all of the other grounds. They're all connected through the chassis itself.
CRXed
Nov 10, 2006 07:45 PM
