Dash light hesitate to come on! HELP
Old Mar 6, 2013 | 06:47 AM
OklahomaEg's Avatar
Default Dash light hesitate to come on! HELP
Whenever I switch my dash lights/corner lights on, sometimes it will wait 5-30 seconds before actually coming on. If it matters I have 2 other power sources wired in with my corner lights, but iirc it has done this since before I wired the other things to it.
Old Mar 6, 2013 | 08:14 AM
grog's Avatar
Default Re: Dash light hesitate to come on! HELP
It may be due to a bad ground, check the appropriate grounds.
You should undo or unplug the extra wiring you added so you can know for sure if its the cause or not.
What is the vehicle and year?
Old Mar 6, 2013 | 08:26 AM
OklahomaEg's Avatar
It is a 1992 civic hatch
Old Mar 6, 2013 | 09:31 AM
fcm's Avatar
fcm
Old Fart
If it is both the dash/cluster lights and your park/driving/corner lights, it is unlikely a grounding problem as the front and read park lights and the dash lights all use different grounds points.
Sounds more like like the combination light switch.
I would test the park light output from the CLS. 94
Arthur Isbell
Honda CR-V & Element
Jul 2, 2018 03:10 PM
hotnsticky5100
Mar 2, 2018 02:12 PM
bambam530
Oct 27, 2013 07:12 PM
hondafreak2134
Oct 10, 2009 05:24 PM
TheJuggalo
Sep 3, 2002 12:35 PM
