bad wheel hub?
Old Mar 5, 2013 | 04:58 PM
alex1320's Avatar
Default bad wheel hub?
ive been moving my car around without axles around the drive way and one day when i was jacking it up there was excessive play in the hub. its pretty bad. people are telling me that its normal and will go away when you put axles in. i just wanted some input before i put my motor back in.
thanks
Old Mar 5, 2013 | 05:13 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: bad wheel hub?
when the axel is put in and tightened it compresses the two halfs of the bearing and takes up the play
if it doesnt fix it with the axel in then the bearing is worn out
Old Mar 5, 2013 | 05:44 PM
alex1320's Avatar
bump
Old Mar 5, 2013 | 08:19 PM
jbpnoman's Avatar
Why are you bumping your thread? You already got the answer. Bearing play should be checked with an axle installed.
Old Mar 6, 2013 | 08:31 AM
Ddixon42's Avatar
It's the berring just got mine done and it fixed the play
Old Mar 6, 2013 | 08:47 AM
kyden's Avatar
if you moved it without axles in, your bearing is probably toast.
PreludeJunkie91
Jul 7, 2018 02:13 PM
dartonh22
Apr 2, 2012 11:55 AM
Cynical 1
Suspension & Brakes
Jan 17, 2011 06:00 PM
418whpturboD
Oct 27, 2008 02:55 PM
