ball joints
my ball joints look like they are about to be shot so im looking to replace them. from what ive read on different sites. advance auto quality is pretty much the same as ebay. im not running much power probably 180whp and my sol is just my DD so im not looking for track parts. my question is, would ebay ball joints hold up fine under DD conditions and the few times i might run it hard or is advance auto or napa a better choice
Generally speaking you wont get much time out cheap parts store ball joints. (I used to get about 6 - 8 months out of them) The OEM Honda balljoints, while costing about double last at least 10 times as long.
Also bear in mind, when a ball joint separates or breaks, that wheel is going under the car and that car is going wherever it feels like it.
SPC makes damn good products and I swear by them (all of my suspension components are either Eibach [coils and shocks] or SPC [ball joints, toe adjustment links, and rear upper control arms] ). Heavy duty and tough as hell. They're not cheap, but they're more than worth it, especially if you beat on your car's suspension daily.
http://www.summitracing.com/search/p...es-ball-joints
I'm assuming lower ball joints? Most people simply replace the upper control arm when the upper ball joint is worn, that's the way Honda sells it.
Regardless...
you can get the MOOG "Problem Solver" lower ball joints for less than $30 each at Rock Auto.
I've seen the OEM Honda ball joints for around $40 each if you shop around.
Regardless...
If they are the lowers, check with Honda regarding service bulletins. Even though the parts catalog doesn't show them as separate, there can be a bulletin with a part # for individual which significantly reduces the cost.
The lowers are separate even in the parts catalog, part number 51220-S04-003. They aren't shown for the '01 - '05 Civics, but they are available (part number 51220-S5A-305 if anyone cares)
I am running Moog UCA's and Raybestos out tie rod ends. I live down a dirt road, and they are holding up nicely. I am at stock height right now, and the front end is still tight as hell. Check out Rock Auto, that is where I buy all my replacement products. You have to look for the best parts though, and be careful not to order anything with the blue flag next to it...you will be waiting a while for the parts.
$42 is dirt cheap really. Canadian prices are very out of wack. Even with my discount at Honda I pay $101 each for them, plus 13% tax. Cheap aftermarket is about $50 each. Unfortunately Majestic Honda wont ship to Canada.
FWIW, my taxi went through four Moog ball joints in two years. Two were out of spec and needed to be replaced, and two failed, unexpectedly and catastrophically. Thankfully both while doing a 3 point in a cul de sac - had they failed at any kind of speed, the car would have been fucked. In those two years, the taxi saw ~80k miles.
No, they weren't for an EJ chassis, but yes, they were Moog. It's a safe assumption they put the same level of craftsmanship into all of their ball joints, regardless of chassis.
I just recently replace my ball joints as well I had bought the first pair threw eBay and trust me when I say this those parts are garbage don't waste your time and money. The sad thing was those cheap *** joints didnt even last me 3 months I bought the moog brand worth every penny happy with the results
