Suspension & Brakes Theory, alignment, spring rates....
93 si rear discs vs integra rear discs
Old Mar 5, 2013 | 01:59 PM
young-gun92eg's Avatar
Default 93 si rear discs vs integra rear discs
so i have a 93 si hatch and it needs all new rear brakes, calipers and all so i was wondering if integra rear discs were any bigger or beter or any diffrent at all. cause if their any beter i mayswell order integra stuff since im buying everything new anyways help or subjestions would be apreciated
Old Mar 5, 2013 | 04:29 PM
98civdx's Avatar
Master Detailer
Default Re: 93 si rear discs vs integra rear discs
It's the same.
if you want an "upgrade" ITR is an option.
Old Mar 5, 2013 | 05:21 PM
alright thank you, is it worth switching to itr ? and do they bolt right on if you have brakets and everything
Old Mar 7, 2013 | 03:00 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Depends on the use of your vehicle... Maybe if your use your car for the ocassional road coarse, it is worth it. Not sure what tires or brake pads you use but that is where I would start personally. I have teg brakes on my hatch with hawk hps pads with Dunlop z1 star specs and my braking power is amazing. IMO
Old Mar 11, 2013 | 01:03 PM
no i dont race on any road cources, theres noweres were i live to do it or i would so just some drag racing and some very spirited street driving. was going to oerder these for rotors and pads http://www.summitracing.com/parts/pw...da/model/civic on the back and i just have stock on the front
Old Mar 11, 2013 | 01:20 PM
sk8shorty012's Avatar
There's really no point in upgrading the rear to ITR unless you plan to upgrade the front as well. If you upgrade just the rear you WILL have bias issues.
Also, the ITR rear upgrade is not a straight-forward as you think. It requires either:
a) ITR rear calipers (hard to find or expensive as re-man)
b) EP3 / RSX rear calipers which requires left on right and right on left - a pain when bleeding brakes
c) Some conversion kit? I think fastbrakes has a kit, but it's probably more expense than it's worth.
d) Five-lug conversion
Old Mar 12, 2013 | 06:20 AM
kyden's Avatar
^^ it can be done with 4 lug. just use 02-03 civic si rotors.
Old Mar 12, 2013 | 09:41 AM
s2kham's Avatar
i have no input, but thanks to ur thread for all the helpful info.
Old Mar 12, 2013 | 09:56 AM
I understand, what calipers would you like to use though? THAT'S the tricky part.
7rrivera7
Mar 8, 2009 04:18 PM
zseeanz
Dec 17, 2006 07:38 AM
DA93TEG!!
Aug 4, 2004 10:46 PM
CRX Si
Nov 17, 2003 01:01 PM
-Racer X-
10
Nov 7, 2002 04:34 PM
