NC S14 Kouki 6.6L 408ci LSx
Old Mar 5, 2013 | 01:29 PM
civicb18Tkid's Avatar
Default S14 Kouki 6.6L 408ci LSx (UPDATE ACCEPTING MORE TRADES)
FEELER: FS or FT: Will sell for $17,500 or trade for a mk4 supra, skyline, S15, boss status s13 coupe, anything RHD, anything Rb26dett, anything 2jzgte (prefer v160 or MT r154), possibly boosted s2k, some LSx cars, corvettes, 03-04 cobra, really anything interesting. If its nice I can add cash on my end. Don't text me with a beat sr20 s13. I don't want it lol. Will entertain other things. Still not sure if ill let her go. Might still boost her, got some parts stock piled already. Who knows what will happen. Text 570-419-7862 car is located in Charlotte NC currently. Will travel. Will ship. Will not give the car away.
TEXT FOR MORE INFO AND PICTURES
240sx Mod List
Engine ( 6.6L 408ci LSx)
LQ9 6L block
Bored .30 over
Eagle forged 4 in stoker crank
Eagle forged H Beam rods
Diamond 2cc flat top forged pistons (http://www.cnc-motorsports.com/pisto...-030-bore.html)
Diamond rings gapped for nitrous 1.5mm/1.5mm/3.0mm ring widths
Diamond Rist pins
Clevite Bearings Main/Rod
ARP Main bolts
ARP Rod bolts
ARP Head bolts
ARP Crank Bolt
Melling Oil Pump
Double Roller timing assembly
Comp Cam Custom Ground 246/250 (@ .500 lift) .630/.630 actual lift
Patriot Gold valve springs
Patriot retainers and valve clips
New valve seals
317 aluminum mild ported heads
Comp Hardened Push Rods
New OEM lifters
Underdrive Pulley
Z06 intake manifold
Custom aluminum intake
42 lb injectors
FAST Fuel rails
Aeromotive FPR
Dual Walbro 255 lb/hr fuel pumps
-8 Braided Black fuel line, -6 Return line
MSD Spark Plug wires
GTO Oil pan/pickup/windage tray
Aluminum radiator
New Water Pump
Hinson LT Headers
Apexi N1 exhaust 2-1 All 3 inch to blast pipe
Custom built motor mounts
Custom built crossmember
Re-pinned harness into factory harness
Tuned on HP Tuners by Ryan Stump at Stumps Garage in Pines Grove
Drive Train
Stage 4 ACT clutch
New Lightened flywheel installed with clutch
Pro 5.0 short shifter
Hurst Pistol Grip Shifter
Rebuilt T56 Trans (3/4th gear from viper, new syncros, new shift pads)
Aluminum one piece drive shaft
Q45
Kaaz 2 way LSD (not installed)
NEW Clutch master cylinder
Stainless braided clutch line
Suspension/brakes
Megan Track Coilovers
-32 way dampening
-12k/10k
-adjustable front camber
Megan rear upper control and toe control arms
Sikky front sway bar
Suspension technique rear sway bar
Polyurethane bushings for front tension arms
Real Brembo Rotors (Z32)
Z32 front brakes
Braided brake lines
Also have 20mm spacers for the rear NOT INSTALLED
Wheels
Work Stitch wheels 9"/10"
g35 no tires
Interior
D1 Racing Wheel
NRG quick release hub
Vanity mirror
New black carpet
Pioneer speakers
Alpine W200 in dash double din DVD player (touch screen)
Prosport Water/Oil pressure/Tach/shift light
Exterior
Kouki Taillights
Tint 5%
Kouki conversion
VIS carbon fiber hood
HID's
Honda Accord rear lip
Misc
Notched inner fender with tucked wiring harness
New custom built crossmember
New control arms
New ball joints
New o2s
Old Mar 5, 2013 | 09:12 PM
AztecEGhatch's Avatar
Default Re: S14 Kouki 6.6L 408ci LSx
wilpo bump!
Old Mar 6, 2013 | 02:22 AM
Discosteak's Avatar
i thought you were insane with 17500 for the price. until i saw the mod list for the motor. GLWS you have a nice car
Old Mar 6, 2013 | 02:29 AM
kemahRSteg's Avatar
i want to hear this thing
Old Mar 6, 2013 | 11:13 AM
Lol up
Old Mar 6, 2013 | 04:56 PM
goldhatch94's Avatar
sick
Old Mar 6, 2013 | 05:30 PM
mEH3's Avatar
Fantastic build!!
Old Mar 6, 2013 | 06:46 PM
sirtef9's Avatar
bump for sickness!
Old Mar 6, 2013 | 07:04 PM
njteggy's Avatar
HOLY ****
Old Mar 7, 2013 | 02:53 AM
Lol thanks guys. Up!
Old Mar 8, 2013 | 01:16 PM
Bumpy
Old Mar 9, 2013 | 06:05 AM
Up up up
Old Mar 10, 2013 | 05:04 AM
BSERIEuS's Avatar
Trade you my Z? LOLLLLLL
Sick car. GLWS
Old Mar 10, 2013 | 06:29 AM
Lol depends. Details?
Old Mar 10, 2013 | 09:45 AM
R6Elmo's Avatar
nice car, any dyno chart or power numbers?
Old Mar 10, 2013 | 11:41 AM
Have all those goodies for those truly interested
Old Mar 11, 2013 | 06:31 AM
qwrty's Avatar
B UM P!!
good luck w/ the sale....
thats a very CLEAN set up!!
Old Mar 11, 2013 | 08:07 AM
Thanks bud
Old Apr 9, 2013 | 04:05 PM
Turbo s2k bump
Old Apr 24, 2013 | 02:59 AM
Up
Old Apr 25, 2013 | 08:02 AM
h2b_sedan's Avatar
check s2000 thread
Old May 8, 2013 | 03:30 PM
Originally Posted by h2b_sedan
check s2000 thread
Texted
akurtzer57
May 21, 2013 10:49 AM
joe0522
Mar 2, 2009 10:07 AM
-CP-
Dec 18, 2002 04:45 PM
