Transmission & Drivetrain Gearboxes, Differentials, Clutches
91 integra cable to hydro questions
Old Mar 5, 2013 | 11:25 AM
90 integra da's Avatar
Default 91 integra cable to hydro questions
Ok, so I am hoping someone can point me in the right direction. I am swapping a hydro gsr transmission into my 91 integra and need to get a few final details.
My question is, my hydro trans obviously has an electronic vss and my car came with a cable setup, what is easiest to do for this swap, buy a cable vss and drop it in the hydro trans? If I do that will the inner speed gear on the diff match up to the gear on the cable vss? I know the stock vss is hooked into the power steering system but I have removed power steering so I do not need to worry about that.
Old Mar 6, 2013 | 04:17 PM
Default Re: 91 integra cable to hydro questions
Well I had searched a lot and found nothing but when I altered my search some more just now it seems that the cable unit will be fine in my trans.
Old Mar 6, 2013 | 04:28 PM
94EG8's Avatar
Seagull Management
I know for the D-series you just use the cable VSS. What I don't know about is if you can use an early cable transmission VSS in a late style cable (YS1) or hydro trans. I'm quite sure it fits the trans, just not sure if the drive gear is different.
Old Mar 6, 2013 | 05:21 PM
MR.johnson's Avatar
i will look at the speedo gear on both the hyrdro and cable and let you know if its the same. give me a few hours.
Old Mar 6, 2013 | 06:37 PM
MR.johnson's Avatar
they are the same your good to go.
Old Mar 6, 2013 | 06:58 PM
94EG8's Avatar
Seagull Management
Which cable VSS was it? YS1 or something else? I know YS1 will work since it's just a hydro trans in a cable case for all intents and purposes.
Old Mar 6, 2013 | 09:33 PM
4g hatch's Avatar
i know when we put a ys1 into my bros crx and tryed using the vss that came with the old cable tranny it fit fine but broke the speedo cable when drove....i assumed it was the vss gear was diff. than the gear on the ys1 diff but i cant say for sure as we didnt go any further, just left it broke. its a b20 non vtec anyway so wasnt worryed bout the speedo.lol
Old Mar 7, 2013 | 08:11 AM
raene's Avatar
I dropped an electronic VSS in a cable box, it's been running fine for years, wouldn't see why the reverse situation wouldn't work.
Old Mar 11, 2013 | 04:32 PM
Thanks guys.
Disco
May 24, 2011 06:12 PM
rice a roni
Dec 6, 2003 04:12 PM
Snail Tuning
Jan 17, 2003 04:53 AM
