Vtec Troubles
Old Oct 21, 2002 | 06:26 PM
dsmith817's Avatar
Default Vtec Troubles
i have a 99 civic si with the following mods: aem intake, dc headers, exhaust, complete pulley set, web cams with titanium springs and retainers, integra type-r pistons. my problem is when vtec kicks in it doesn't really do much. i've checked the vtec solenoid and it is in good shape also replaced the map sensor. timing is good. fuel is also doing good. the valve clearances are within spec as well. i was thinking maybe oil pressure? one weird thing is every now and then, the vtec will kick in really hard and make an enormous difference, but 95% of the time it just makes noise and doesn't do much. any help would be great. thanks alot.
Old Oct 21, 2002 | 06:32 PM
Kamin's Avatar
Default Re: Vtec Troubles (dsmith817)
https://honda-tech.com/zerothread?id=164863
Old Oct 21, 2002 | 06:53 PM
dsmith817's Avatar
one thing i noticed from reading that thread you linked me to is my speedometer doesn't exactly work right. it's off by 5-10mph. my tach also doesnt work very well. the guy who owned the car before me took the entire pin out and tried to plug it back in. could this be a factor??????
Old Oct 21, 2002 | 11:44 PM
Kamin's Avatar
as long as you are getting a signal to the spedo (meaning it works at all) it will work
I had a severe problem with my spedo for a while (bad connection on harness side of VSS)
vtec worked but my spedo would flutter up and down. meaning if i steped on the gas it would fly up to 80+mph then flutter down to normal speed while cruising.
RR_si
Honda Civic (2006 - 2015)
Jan 23, 2010 11:53 AM
XSIintegra
Mar 25, 2008 06:35 PM
civicx
12
Aug 25, 2005 06:44 PM
acmeotally
Jul 28, 2005 02:26 PM
GiT LaO'd
Nov 22, 2004 04:24 AM
