Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help me figure out this,Tranny 2nd gear whining
Old Mar 4, 2013 | 11:37 PM
tranza's Avatar
Default Help me figure out this,Tranny 2nd gear whining
My ls trannny is making a whining sound (like going in reverse not that loud, but a noticeable "weee") only a LOW RPM and like at 20mph, it does it a 1st, then get a lil be louder at 2nd, then everything is ok at 3rd,4rd, 5th.
The sound goes away if i push the gas, its only make it when i stop pushing gas and RPM start to go down.
What could this be, i opened the tranny last week and only first gear set teeth had a lil be wear out.
What should i check?.
Old Mar 4, 2013 | 11:48 PM
FearSC549's Avatar
Default Re: Help me figure out this,Tranny 2nd gear whining
The ISB (input shaft bearing) is closest to 1st gear, and the noise/jerks gets progressively quieter as you go up in gears. Check your other bearings for play too.
Old Mar 4, 2013 | 11:57 PM
tranza's Avatar
The sound goes away if i push the clutch in, i thought if the ISB was bad it will continue to make the noise even with the clutch in.
Old Mar 5, 2013 | 12:17 AM
tranza's Avatar
And it's only making this sound when the car is moving.
Old Mar 5, 2013 | 06:27 AM
94EG8's Avatar
Seagull Management
Nope. The noise only goes away with the clutch in.
Honestly it sounds like a chipped tooth on 2nd or a mixmatched gearset to me.
Old Mar 5, 2013 | 10:33 AM
tranza's Avatar
Hi, thanks for you help.
Before opening up the tranny last week and disassembly it, it was making this noise from all the gear but not that loud, but now its only making it on 2nd gear and lil be more louder, here is a video i recorderd from 1:20 to 2:00 you can clear hear it. From 4:00 you can see the full push from 1-3 gear
You can notice how it disappear on 3rd gear, and its only making in on LOW RPM 2nd gear.
Old Mar 6, 2013 | 12:34 PM
94EG8's Avatar
Seagull Management
I watched your video, but honestly, between me having a little hearing loss and the loud exhaust I really can't tell you anything from the video.
Did you replace the ISB when you had it apart? If not start there.
Old Mar 7, 2013 | 08:42 AM
tranza's Avatar
I didnt replace the ISB, cause it didnt see to be bad. If you put the video on time 1:20 you can hear the noise when i stop pushing gas, its like a "weee" noise.
Old Mar 11, 2013 | 02:36 AM
FearSC549's Avatar
The ISB is bad. Replace it.
rubocop
Apr 13, 2015 10:03 PM
TeamProjectZero
May 7, 2010 06:24 AM
itsLOUiSduh
Mar 9, 2009 08:35 PM
kevinf_69
20
Feb 18, 2009 11:44 AM
SlowestEJ8
14
Dec 29, 2005 03:26 PM
