91 d16y7 hatch need a/c
Old Mar 4, 2013 | 06:39 PM
McKinky's Avatar
Default 91 d16y7 hatch need a/c
So with the heat on its way the misses would like to know if its possible to install a/c into our hatch.
I need to find out what to use so everything works if even possible. Like would the EF a/c bracket bolt onto the EK block or EF compressor bolt onto the EK a/c bracket?
I tried looking for an aftermarket bracket but all I could find were B series conversions
Thanks in advance for anyone who helps.
Old Mar 4, 2013 | 08:09 PM
rallypoint_1's Avatar
Default Re: 91 d16y7 hatch need a/c
You would have to use evertyhing for an EF up to the compressor. I don't think the compressor bracket for an EF will fit on your motor. I dont see why a EK compressor and bracket would not fit. Unless the threads to attach the ac hose is different.
Anyways here is what you need assuming there are no ac parts already on your car.
Ac loom, evaporator, all lines, ac fan, condensor, drier and compressor w/bracket.
Old Mar 6, 2013 | 04:25 PM
McKinky's Avatar
Hmm so d15b2 bracket will not fit on d16y7 so does anybody know if d15b2 compressor bolt to the d16y7 bracket?
Old Mar 8, 2013 | 05:26 PM
SPIKE'S91CIVICSI's Avatar
I installed my bracket for a6 into my y7.they bolt right up.i would assume its the same as b2...
Old Mar 11, 2013 | 11:06 PM
McKinky's Avatar
Ok thank you that is exactly what i needed to know
I can pick up a b2 bracket if thats a no go then a6 it is
EfB18
Jun 24, 2015 10:02 AM
brownsEF
Jul 3, 2011 02:05 PM
on2wheels
10
Dec 8, 2005 01:15 PM
Wes V
Sep 3, 2005 09:08 AM
