96 Honda Civic. HELP!
Old Mar 4, 2013 | 06:11 PM
bigace202's Avatar
Default 96 Honda Civic. HELP!
Hey guys, new to the forum. Figured I can get some informative help on here. I have on 96 Honda Civic LX and my issue with it is when the car heats up it doesn't like to start. For example, I made a Chipotle run the other night. After I got my food I got in the crank and it wouldn't start up. It still cranks but it refuses to start up. Waited 25-30 mins in the car then it started up with no problem. Any ideas? Thanks for reading
Old Mar 4, 2013 | 06:18 PM
HOMEMADEPOWER's Avatar
Default Re: 96 Honda Civic. HELP!
Is the CEL on?
Old Mar 4, 2013 | 10:21 PM
eghatch9295's Avatar
Stancetard Hate Monger
coil.
Old Mar 4, 2013 | 11:08 PM
JKing106's Avatar
Or the ICM (ignition control module.)
Posted from Honda-tech.com App for Android
Old Mar 4, 2013 | 11:14 PM
Erikthetech's Avatar
make sure the car is not over heating and make sure you have coolant in the car and also make sure the fans are turning on
Old Mar 4, 2013 | 11:38 PM
jbpnoman's Avatar
It could be a number of things.
OP, when your car doesn't start, listen for the fuel pump. The main relay is a common point of failure in our cars, and not starting while hot is a common symptom of main relay failure. If you can't hear the fuel pump prime when your car is hot, test your main relay. I believe there is a how-to in the FAQ's sticky.
Old Mar 5, 2013 | 01:42 PM
bigace202's Avatar
Hey guys, really appreciate the help. The coil was recently changed. I just got my car scanned and the troubleshooting code was P0118. I believe its an electrical problem? Any ideas?
Old Mar 5, 2013 | 08:23 PM
jbpnoman's Avatar
ECT sensor code. Do you have access to a voltmeter?
Old Mar 7, 2013 | 08:10 PM
bigace202's Avatar
Yes i do have access to a voltmeter
Old Mar 7, 2013 | 08:12 PM
jdmperez's Avatar
might need to change the ECT sensor seems like it's only register when the engine is hot
Brand
21
Sep 8, 2022 09:39 AM
brendagoodnight
Feb 9, 2014 10:37 AM
bam99
Mar 2, 2010 08:02 AM
mugen12_35sec
Nov 26, 2007 07:40 PM
