PLZ help / 1993 accord head light
hey guys i really hope i find quick answer here .
I have honda 1993 accord and the head lights are not working , it actually works for while and then goes out again so i believe its wiring problem .
i need to use the car and dont have alot of time to go to a mechanic or fix it myself .
MY QUESTION
Can i take bridge wire from the other working head light untill i have time to fix this or this will put heavy load on the fuses ?
thank you very much
MY QUESTION
thank you very much
Just check the two common grounds in the front of the car. You will have to remove the bumper. They should have about 20 or so wires going into a white plug, this plug is the common ground and will be bolted to the chassis.
blau
Jul 9, 2008 02:46 PM
