OBD0-OBD1 Conversion, Crank but no start!?
So I went about and bought a p28 OBD1 ECU, an obd0-obd1 Conversion ECU harness, and a obd1 Distributor, hooked it all up and all I get is cranking and electrical stuff to go on but no SPARK!
Prior to this, the last person who swapped it had a JDM PR3 VTEC ECU ,so all the VTEC and O2 Sensors are plugged into the old OBD0 Harness, could this be my problem? Theres a bunch of wires spliced and cut from the original OBD0 Harness, should I just connect my ground wires, VTEC, o2 sensor directly using the extra wires that my jumper came with?
I'm running oBd0 MPFI on 88 Hatchback
Pancho2193
Mar 4, 2013 05:33 AM
dem0nk1d
32
Sep 15, 2007 11:49 PM
