Manual Side Mirror is stuck, cant adjust it
Old Mar 3, 2013 | 12:00 PM
Vagitarian's Avatar
Default Manual Side Mirror is stuck, cant adjust it
I bought a set of new door for my crx and the mirrors that came on them are manual with the control **** inside.
The passenger side glass mirror cannot be adjusted, its stuck solid it feels, not budging at all, even by trying to push on the corners of the glass I cannot adjust the view angle.
Is something broken inside and I should get a new side mirror, or can something be fixed/looked at inside behind the glass??
Old Mar 3, 2013 | 02:27 PM
redhatch 1964's Avatar
Default Re: Manual Side Mirror is stuck, cant adjust it
The mirror can be dissembled. The hole in the bottom of the mirror is access for the pinch screw on the ball socket. Loosen the screw with a phillips screwdriver and then use a flat screwdriver at the outside edge to pry the mirror from the housing. You can then see the mechanics of the mirror. Use liquid wrench to loosen up the links.
DeDonDeRosa
Dec 26, 2004 10:33 AM
MiKrofT
Nov 6, 2002 05:52 PM
