Suspension & Brakes Theory, alignment, spring rates....
Rear camber kits? Factory bushings are shot
Old Mar 3, 2013 | 07:42 AM
Racer02gtstang's Avatar
Default Rear camber kits? Factory bushings are shot
Well I'm going to be lowering my 99 ex here soon and adding a rear sway and such. I've been thinking of the eibach pro system since Its my daily driver and I don't want a rough ride and not too much drop. But my rear upper control arm bushings are worn out so I'm thinking of just doing a rear camber kit since my camber is already almost out due to the bad bushings and I don't feel like going oem arms. So what are some good options for the rear upper arms? I've got spc Arms on my bmw. Are they pretty good on the civics as well?
Old Mar 3, 2013 | 08:11 AM
98civdx's Avatar
Master Detailer
Default Re: Rear camber kits? Factory bushings are shot
SPC would be an awesome choice if you have to have them.
Honestly I would get new OEM UCA's and throw a couple washers in and be done with it.
Old Mar 3, 2013 | 12:13 PM
FlewByU352's Avatar
DO NOT! I repeat DO NOT buy Skunk2 rear camber kits unless you like positive camber. They don't call it Junk2 for a reason, my car maxing out the threaded adjustment on them would only pull -1.1 degrees camber with the car lowered quite a bit.
Old Mar 3, 2013 | 01:20 PM
GagnarTheUnruly's Avatar
OEM arms are the best.
Old Mar 3, 2013 | 01:33 PM
98civdx's Avatar
Master Detailer
^SPC is next in line.
Also to add to the skunk2, don't forget they are squeaky as hell!
Old Mar 10, 2013 | 09:23 AM
Ok. Well I'm thinking I'm gonna get the spc arms then. I get them cheaper ordering through work I found out. I just ordered the eibach pro system plus through work for 620 shipped. Now I'm wondering about which rear sway bar brace to go with and possible rear lower control arms while I'm at it ?
Old Mar 10, 2013 | 09:39 AM
Andy@AMR's Avatar
You could have probably been better off just going with a hardened rubber bushing kit. If the rear upper control arm bushings are already shot then it's very likely the rest are going to be the same condition soon.
If you really want to replace the rear lower control arms, Function 7 is the best. We are a distributor, and also have a rear camber kit.
I'd look into a full bushing kit though in the future. For swaybars the 24mm ASR is a good start or a used ITR.
Old Mar 10, 2013 | 10:23 AM
Well I put new honda trailing arm bushing in about 2k miles ago when I did a rear disk swap. I also ordered all now shock top mountbushings from work for when i do the springs and strutsAnd the kit I ordered has a 17mm rear sway from eibach which is enough for a dd. but I'm told a brace is recommended for anything over a si 13mm sway bar. What's your price on a rear subframe brace function 7 lower arms and spc camber arms? You can pm me if needed. I was priced the spc camber arms for 45 each plus shipping
Old Mar 10, 2013 | 04:10 PM
98civdx's Avatar
Master Detailer
You don't need a brace for the 17mm bar. Braces are recommended past 17-19mm.
drsab2000
12
Oct 31, 2013 09:39 AM
NY_2_OC
Suspension & Brakes
Feb 3, 2012 09:35 PM
Blacksole
Honda S2000
Nov 9, 2011 06:58 AM
5Point7Liter
Suspension & Brakes
Dec 26, 2006 03:45 PM
EG2Driver
Suspension & Brakes
May 9, 2006 12:17 PM
