Recaro Pole Position SPG - which rails?
Old Mar 3, 2013 | 02:40 AM
jimlaH's Avatar
Default Recaro Pole Position SPG - which rails?
Hey guys just purchased 2x recaro pole position spg seats for my DC2R
both seats have the side mount brackets i just dont know
which rails to use with them.
will dc2r recaro sr3 rails bolt up to the side mount brackets?
or do i use something else like bride RO rails?
pics of the seats
Old Mar 3, 2013 | 05:10 AM
Devon M's Avatar
Default Re: Recaro Pole Position SPG - which rails?
Buddy club rails work well, PCI work well but don't have sliders. You could also buy the sparco brackets and sliders to bolt to the recaro side rails. If you go that route pm me, I have a new set I'd let go for cheap.
Old Mar 3, 2013 | 06:48 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Buddy club rails are sooooo awful.
Old Mar 3, 2013 | 11:06 AM
Devon M's Avatar
Personally I have never used them. Why do you say that? Too much movement?
Old Mar 3, 2013 | 07:24 PM
jdmspoonitr's Avatar
You can use Mugen, Bride, etc.
Old Mar 3, 2013 | 08:17 PM
jimlaH's Avatar
which bride rails? bride type ro?
Old Mar 3, 2013 | 08:27 PM
B serious's Avatar
The welds commonly break (atleast on S2000 rails). Ironically, I had read about people breaking their welds, and I removed my seats to check. The rear attachment point weld was busted. I'm not a big guy...5'11, 165-170LBS. It's not like I weigh 300lbs and jump into my seat from the 2nd floor.
I had both rails re-welded solid. The problem is that buddy club only spot welds on one point to join the attachment points. The sliders are constantly coming loose, so the seat jiggles, and inspite of that.... the sliders have way too much resistance when you try to move them.
Old Mar 4, 2013 | 02:02 AM
Devon M's Avatar
Good to know for future reference.
Old Mar 4, 2013 | 08:44 AM
3rdtimecharmer's Avatar
10 Year Member
call up wedge engineering
Old Mar 5, 2013 | 10:01 AM
Bride has two types of rails. Ones meant for bottom mount seats and ones meant for side mount seats. SPG's are side mount. You might need to modify those Recaro side plates to mount on Bride rails. By modify I mean use a dremel and cut out a small section.
You can also use the supplied side brackets that come with the Bride rails, which essentially look like little L brackets with holes drilled in them.
Old Mar 27, 2013 | 02:01 AM
jimlaH's Avatar
just tried my friends PCI rails, the seats sit off centre about an inch towards the door, will try flipping the brackets around to hopefully gain more clearance so i can slide the seat in towards the middle of the car.
does any1 know if buddyclub rails sit the seat perfectly centered in a dc2?
Old Mar 27, 2013 | 05:20 AM
itrSteez's Avatar
PCI's rule, I loved mine.
ps: my passenger one is for sale
Old Mar 27, 2013 | 06:15 AM
teg97's Avatar
great seller btw! buy with confidence!
Old Mar 28, 2013 | 03:30 PM
coolhandluke's Avatar
Originally Posted by jdmspoonitr
You can use Mugen...
Mugen won't work with the wider Recaro seats.
I have owned two sets of Buddy Club rails, no issues.
Old Mar 28, 2013 | 03:56 PM
jimlaH's Avatar
Cheers Luke! Seems like buddy club rails are the way to go
Old Mar 28, 2013 | 07:57 PM
yztzzxga's Avatar
Old Mar 28, 2013 | 09:19 PM
Finland's Avatar
when I had aftermarket Recaro seats in my car, I used Sparco 400SB018R/L part number mounts with standard universal Recaro sliders. Easypeasy.
big.turbo.daddy
May 19, 2014 12:13 AM
Twenty47
Jul 21, 2008 01:06 PM
MugenGTR
Sep 23, 2006 11:18 PM
92jdmhatch
Honda S2000
11
Jan 1, 2005 10:12 AM
RTW DC2R
Dec 5, 2002 01:52 PM
