may sound stupid but just curious!
Old Mar 2, 2013 | 12:37 PM
murphydennis17's Avatar
Default may sound stupid but just curious!
I see everyone calling their motor names such as h22 or b18....what would be in a 99 Honda accord ex 4cyl 5 speed. I checked the vin and it said 2.3L I4 EFI is that the only name for it?
Old Mar 2, 2013 | 12:39 PM
Default Re: may sound stupid but just curious!
and is that a "good engine"?
Old Mar 2, 2013 | 12:43 PM
gdrew888's Avatar
Hi, this link will tell you where to look on a 90-91-92-93...don't know about a 99.
https://honda-tech.com/forums/honda-accord-1990-2002-2/r2d2-3cpo-3116065/
Old Mar 2, 2013 | 12:51 PM
cool thank you I found it! is a f23a1 a good motor?
Old Mar 2, 2013 | 01:03 PM
JuggerNaut-CTR's Avatar
Define "good"
All honda motors are ubber reliable when cared for.
Old Mar 2, 2013 | 01:07 PM
umm..as far as I read a lot that people are doing engine swaps..would this be a motor they swap for or the motor being swaped out???
Old Mar 2, 2013 | 01:39 PM
NZXTInerTia's Avatar
You have a F23A1 2.3l SOHC VTEC, early 90's Accords to Early 2000's Accords all used the same basic block premise with different head setups. The F series (Minus the F20a,b,c which were DOHC) have SOHC heads, while the H series all have DOHC heads. All reliable motors when cared for properly, the H series have proven to be fairly powerful on N/A and boosted setups. Lately people have been working on and building up the F series motors due to more aftermarket parts being more available and cheaper to obtain with decent numbers.
F Series: http://en.wikipedia.org/wiki/Honda_F_engine
H Series: http://en.wikipedia.org/wiki/Honda_H_Engine
Old Mar 2, 2013 | 07:49 PM
Cali_Accord's Avatar
You get more hp w/ the H22, they come from preludes.. Make sure it's from Japan.. You can find urself having trouble smoging tho, so hook ur ride up and make sure you have a guy u can pay a couple hundred more to pass ur car
Old Mar 2, 2013 | 07:58 PM
[QUOTE=NZXTInerTia;48520976] Lately people have been working on and building up the F series motors due to more aftermarket parts being more available and cheaper to obtain with decent numbers.
I happen to own an F22b2 engine.. What modz can be done to reach the amount of hp provided by the H22 jdm swap?? H22 is a perfect fit btw for accordz 94_97..
Old Mar 2, 2013 | 08:02 PM
Who says the op is even swapping the motor? He is asking about the motor in his car.
Just b/c you live in a smog **** state doesnt mean everyone else does.
Thanks for contributing, but seems as if you are way jumping the gun...
Old Mar 2, 2013 | 08:12 PM
I happen to own an F22b2 engine.. What modz can be done to reach the amount of hp provided by the H22 jdm swap?? H22 is a perfect fit accordz 94_97
Boost it, swap on a h22 head to the current f22 block, or build the f22 (higher compression/bigger cam).
Old Mar 2, 2013 | 08:24 PM
I just don't see an H head on an F block being a wise decision. People have compression issues with them all the time. You're better off swapping because EVERYTHING is original to itself and it works out of the crate. Anyways lets not thread jack.
Agreed on the cam and turbo, although a turbo is a good amount of money they will eventually pay themselves off in the gained power you will get out of installing one. A larger diameter exhaust and a header will also increase some power, but will be louder and won't pass smog (At least I don't think so, don't quote me on this). Don't invest in an intake, they generally have proven to make the engine loose power.
Old Mar 2, 2013 | 08:31 PM
diesel718's Avatar
your crazy, that setup has been done numerous times...f22 block, h22 head, f23 crank, type-s pistons and u have an all motor monster! or use low compression forged pistons and have a turbo monster!!! no compression problems at all if built right..
I agree with the g22. Although, i have owned one and was as you described until the block had work done.
The noob asked, so i told. Not worth the argument you usually get with trial users about starting their own damn thread.
Old Mar 2, 2013 | 08:33 PM
diesel718's Avatar
why does it have to be from japan???? lol......it can be usdm also
Old Mar 2, 2013 | 08:35 PM
Originally Posted by diesel718
your crazy, that setup has been done numerous times...f22 block, h22 head, f23 crank, type-s pistons and u have an all motor monster! ..
Thats the setup i did and was awesome. Motor was a bitch with the stock f22 block though.
Old Mar 2, 2013 | 08:36 PM
diesel718's Avatar
you have many options to swap in....
kseries
h22 whether stock h22 or h22 head on h23 nonvtec block)
h23 euro r
h22 head on f22 block with f23 crank (g-series is what they call it)
h22 head f23 block
j-series
Old Mar 2, 2013 | 08:39 PM
diesel718's Avatar
i know a few people that did it also and one of them were running 11s all motor in an eg hatch but he that bolted up to a b16 tranny, hense the g2b swap
its a great setup if built right...
Old Mar 2, 2013 | 08:43 PM
diesel718's Avatar
lmaooo....yea it just amazes me me with some of the comment half these idiots leave when they know nothing about building a motor or let alone see it done lol.....they think they know everything and half of the people here still cant spell VTEC right lol
Old Mar 3, 2013 | 12:00 AM
Were you talking about me? If so, I know my stuff to an extent lol
That's what I meant. Simply bolting an H22 head on an F22 won't show THAT impressive of a gain. I'm perfectly aware of the numerous people that have done up G22's and had awesome results.
Old Mar 3, 2013 | 04:03 PM
Well Thxz all for advice and ideas on building an accord!! I am new to Honda tech, didn't mean to cause tension between members :/ I'm here to get help, and help others if i can.. I was speaking on behalf of a guy that ownz a power shop, and customizes cars, mainly Hondas, acuras, ect.. I am new in RL to the Honda scene, what i have heard is to get the H22 because it fitz perfectly in the accord.. I've been told to stay away from turbo, it will burn out the engine faster, any engine.. Again i apologize for offending any of you "expertz".. I got my 96 accord stock, i did most the work on it myself.. All except tires and rims.. And cat back.. Latez
Old Mar 3, 2013 | 05:31 PM
so is it not such a good idea to just build up the F23A1. or are yous just suggesting a swap for MORE power??
Old Mar 3, 2013 | 06:31 PM
It's all up to you bro!! who cares what people think.. Ive been meeting alot of different car enthusiast peoples lately, and it seems they all have different things to say about the " ACCORD " .. But i can tell you this man, I've done some stuff to my car that's given me a significant amount of power and is just plan nice to have on the rode.. If your ready financially to do an engine swap then do it.. Or just build up your F23 bro.. Starting with, intake system, headers, cat back, lowering struts.. And ect. ect. Bro, that's the thing I've noticed with being a car enthusiast " You can put 5k in your ride , and start all over if you want!! " but yea dude, i only mention the H22 in regard to power.. H22 complete engine is what id do.. Not a bunch of s/$! Put together, no offense to any one who liked this build better
Old Mar 3, 2013 | 06:38 PM
F22, F23, H22?!?! I LOVE MY ACCORD!! #thats what = worthy.. I just rebuilt the tranny and engine, yet im debating dropping in an H22 , Ha.. Not sure yet :/
Old Mar 3, 2013 | 06:44 PM
Whats a intake "system"? Dont you know a stock airbox is just as good as a intake on a motor that has zero internal work done? Stock motor, they change the sound and maybe, maybe mpg's.
Its a i-4, not a v6...A header will net such small power gain, even with a tune on a stock motor.
I would invest money elsewhere than i/h/e. With the money people spend on bolt ons, he could have a h22 in the car and would perform much better with stock exhaust and intake than a bolt on single jingle.
First time i've ever heard someone say "lowering struts". That was cute.
