Transmission & Drivetrain Gearboxes, Differentials, Clutches
Kaaz diff comes with bearing?
Old Mar 2, 2013 | 07:00 AM
maxogsr's Avatar
Default Kaaz diff comes with bearing?
Ok here's a short story... I'm in the preocess of changing my b-serie OEM lsd for a Kaaz... There was alwready ball bearing on both side of the KAAZ installed that I bought... Does Kaaz supplied the Kaaz with bearing alwready on it? Cause mine is an open box return... The guy that both it before me had an older casing... Anyways, I need to know if the kaaz comes with ball bearing on both ends of the diff...
I know I'll have to shim the diff to get the right tolerance between the diff and housing on both side...
right now, with the KaaZ in and the shim in (1.35mm) in the clutch side housing (the one that was there) I have a gap of about 2.48mm on the other side (gear side housing) with a feeler gage, witch is huge... Actually, Honda in the manual don't even offer that size, it stop at 1.83mm... The clearance should be within 0.1mm...
Could the bearing alwready on the KAAz are too thin witch would cause the "huge" gap?
Old Mar 2, 2013 | 07:32 PM
Aquafina's Avatar
Default Re: Kaaz diff comes with bearing?
No diffs come with bearings installed already.
Old Mar 3, 2013 | 07:02 AM
maxogsr's Avatar
That confirm what I thought....
I'll take these bearings out and put the OEM that I bought at the dealer and check back my clearance.... Cause 3.5mm clearance dosen't make sense...
Old Mar 3, 2013 | 07:06 AM
maxogsr's Avatar
I actually put both my old oem lsd and my new KAaz side to side and have put a level on both at the same time and the KAaz with the "F.A.G" bearing is shorter so...
Old Mar 4, 2013 | 08:08 PM
Aquafina's Avatar
Pictures?
Old Mar 11, 2013 | 09:51 AM
maxogsr's Avatar
I finally found out that tje ntn bearing supply by honda is a bit offset at the center compare to the *** bearing That were on the laaz when I purchase... Now bearing are out. I should be fine with the clearance with the oem bearing...
Old Mar 11, 2013 | 11:19 AM
parts@synchrotech's Avatar
Its not the brand in particular where you are finding the difference. It is the application.
B16/LS all use one type of differential bearing
Early GSR/Type R will use a 2pc Taper bearing
Late model GSR/Type R will use the offset bearing like the one you got from Honda
An easy thing to remember when choosing a differential bearing:
If it is a GSR/Type Diff - Use a GSR/Type R Differential Bearing
If it is a B16/LS Diff - Use a B16/LS Differetial Bearing
Old Mar 11, 2013 | 11:37 AM
maxogsr's Avatar
I agree and was aware of the 2 types of gsr type r bearing. I wasen t aware about the b16a/ ls bearing difference... it make sense cause the reason why the guy return the kaaz was because he had a first gen b16 tranny and apparently the kaaz wasen t fitting in the case... Hope this info will be usefull for some other people!
Old Mar 11, 2013 | 11:39 AM
I need to take a better picture to illustrate the difference. But you understand the 1mm offset difference on the inside.
Old Mar 11, 2013 | 02:21 PM
maxogsr's Avatar
Here's the difference! B16/ls on the left and itr/gsr on the right...
Old Mar 11, 2013 | 02:25 PM
maxogsr's Avatar
BTW, I install all new carbon syncro 1 to 5 from you guys and can't wait to put everything back together and for the snow to melt to go give a try to that new set up!
KaaZ, 4.785fd, carbon syncro and k tune shifter!
Old Mar 12, 2013 | 06:43 AM
Thanks for posting that pic! Perfect display of the difference Nice build
LocoJoe
Mar 2, 2011 06:55 PM
DaiJekBok
May 23, 2006 01:45 PM
AllMotorB
Feb 26, 2006 07:21 PM
RicTRD
Jun 10, 2005 02:43 PM
