cab drone too annoying
Old Mar 1, 2013 | 02:17 PM
driftguy2008's Avatar
Default cab drone too annoying
hey HT after i got my new to me 94 hatch to run good today i decided to drive it around after i changed the oil and my exhaust is annoying at times i love the sound but after a certain rpm i can stand it, it makes my ears ring. i dont wanna buy another exhaust it has a cat back apexi 3" exhaust which sounds awesome but too annoying after 30 mins of driving. what can i do to enjoy driving my civic instead of hating it cause it makes my ears ring.
Old Mar 1, 2013 | 02:33 PM
B_Swapped93's Avatar
Default Re: cab drone too annoying
You could put "dynamat" in the trunk hatch(don't know if i spelled that right) a lot of audio guys do it. It's basicly extra sound deadning costs/weighs a bit but how much you put is up to you. There have been posts like this before end result was some sort of dynamat installed.
Old Mar 1, 2013 | 02:36 PM
EFfin Sedan 91's Avatar
Change the muffler or add on some resonators. 3" exhaust is overkill if you're not turbo.
Old Mar 1, 2013 | 03:00 PM
APEXI comes with a resinator. A different muffler won't change much he's running 3'' exhaust. Dynamat is the simplest solution with out messing with the exhaust which i don't think he want's to do.
Old Mar 1, 2013 | 03:21 PM
jbpnoman's Avatar
You could toss a turbo on it. That'll quiet it down, and give you an actual reason to have 3" piping.
Old Mar 1, 2013 | 03:38 PM
94preludeguy's Avatar
Dynamat won't do ****. I had a Z6 coupe that used to be boosted and had 3" exhaust. Did lots of fatmat and it was hardly any quieter.
My hatch has atleast 2.5 with a resonator and it is pretty quiet. Factory cat is still on though. Not having a converter on the car will make it much louder than any exhaust will.
Old Mar 1, 2013 | 03:40 PM
dirty19's Avatar
Ridin Dirty in Cali
replace the whole exhaust!
Old Mar 1, 2013 | 03:54 PM
Just noticed OP's sig im assuming he's running a 3 inch on a D15 ??. What's the point of that get a 2.25 exhaust and you won't have that droning.
Old Mar 1, 2013 | 04:29 PM
vitamin_c95's Avatar
Post a pic. Sometimes if the muffler isn't sticking far enough past the underside, you get drone inside/under the car bouncing the sound back into passenger area. Versus it sticking out just enough to where the sound is actually going straight out the back
Old Mar 1, 2013 | 04:37 PM
grumblemarc's Avatar
The Grumpiest
Maybe it's just a 3" tip. Can't see why you would need 3" piping on a stock D.
Old Mar 1, 2013 | 04:38 PM
hwyix's Avatar
ding ding
Your new exhaust needs to be as thick as the OEM pipe. If go to the cheapest guy on craigslist he has to cut corners some how. If you get thinner pipe it will ring/vibrate/resonate/etc...
Old Mar 1, 2013 | 04:40 PM
He says catback in his post.
Old Mar 1, 2013 | 04:43 PM
its 3" cat back, i have no clue what size it is header to cat.
Old Mar 1, 2013 | 04:46 PM
The Grumpiest
Just looks like the tip and not the piping. Even if it is just have a muffler shop install another resonator.
Old Mar 1, 2013 | 04:57 PM
how much will that cost?
Old Mar 1, 2013 | 04:59 PM
The Grumpiest
Parts and labor.
Old Mar 1, 2013 | 05:05 PM
what brand resonator should i go with? i found one for $89 3" resonator off some site all i did was google it and first site i found. and how much would you say it would cost for labor and parts?
Old Mar 1, 2013 | 05:07 PM
The Grumpiest
Before you rush off and buy parts maybe you should actually get under the car and VERIFY what you actually have installed. Then call or trot over to a local muffler shop and get a quote from them, not us.
I can tell you all day long what it will cost here but pricing across the country isn't the same.
Old Mar 2, 2013 | 05:20 AM
angrysmileyface's Avatar
Change it out for a Cherrybomb.... Then you can annoy everyone including yourself :-D!
Old Mar 2, 2013 | 05:29 AM
Yomage_EG's Avatar
Old Mar 2, 2013 | 05:45 AM
Fnix's Avatar
I got to use ear plugs. No Panels and no back seats = ear drum damage
Old Mar 3, 2013 | 11:18 AM
I will never understand why people want such loud **** on their slow N/A Honda. Every car I've purchased with loud exhaust I hated it.
Old Mar 3, 2013 | 03:46 PM
hwyix's Avatar
What he said.
I am guilty of buying a free low exhaust. Enjoying the music for a few years and then want something quieter but still produce more power than OEM. I never did find the unicorn exhaust.
Old Mar 3, 2013 | 06:09 PM
fasterthanueg's Avatar
That would be 2.25 pipe with a s2000 muffler
Old Mar 3, 2013 | 06:14 PM
hwyix's Avatar
Was this for me?
I was mostly talking about other car 94 rx7 I had set up for the track.
Now I have 93 hatch/gsr motor that is a little on the noisy side.
Would this S2000 muffler work on my car?
