1996 ACCORD A/C QUESTION
Old Mar 1, 2013 | 11:24 AM
billybobdad's Avatar
Icon2 1996 ACCORD A/C QUESTION
I am considersidering purchasing a 96 Accord Wagon. In inspecting the car we noticed that the AC when turned on was not blowing cold air just warm air. It was found that the AC coolant level was sufficient but the compresor & compressor fan were not kicking in. A mechanic checked and it a put a jumper on the compressor contacts & the compressor came on but the compressor fan did not. When the compressor came on the AC immediately began kicking out cold air. So the the question here is are the compressor & fan interlocked so that if either the compressor and or the fan are faulty that niether will function?
Old Mar 1, 2013 | 03:34 PM
holmesnmanny's Avatar
Default Re: 1996 ACCORD A/C QUESTION
First, have em check the pressure in the system using ac manifold gauges. If it's within specs. Have em rejumper the compressor, then have em jumper the ac pressure switch and see if the fan comes on. If it does, replace the pressure switch. Obviously you'd have to have em evacuate the system before replacing the pressure switch and recharge it after.
Old Mar 2, 2013 | 01:33 AM
Just to add, it's best(and sometimes necessary to keep the evaporator from freezing within a short time of the compressor kicking on and the thermostat from turning the compressor off) to replace the expansion valve...and also the receiver/dryver when you open the system and if you haven't replaced those parts before.
Single-Cam
16
Feb 10, 2016 07:23 PM
Ajak
Jun 17, 2014 02:56 PM
ThisBeDuy
Sep 30, 2011 09:16 AM
adam_n_tg
Sep 12, 2011 10:01 PM
Mad Money
Aug 24, 2006 02:26 PM
