$900 B18A COMPLETE swap - $200 D15b2/Y7 complete swap - Other misc
$900 BEST OFFER ..... WILL NEGOTIATE, TAKING UP PRECIOUS GARAGE SPACE!
Complete swap came from a running 1993 Acura Integra LS 4-door 5spd with 177,161mi. Car was being sent to the scrapyard by a co-worker because it needed a clutch, tires, suspension, and the body was rusting apart. I drove it 60mi from north of Chicago to Yorkville. I do not know if it burns oil, or if the transmission grinds because, like i said, i only drove it 60mi with the clutch that was on its last leg. I babied it because i didnt know the condition. Being Sold AS-IS.
The following is a list of what comes with this package:
B18A Complete Longblock including, engine harness, manifolds, throttle body, injectors w/resistor box, transmission mount, etc.
S1 Transmission w/axles, intermediate shaft, and shift linkage with no name short shifter and 3 of 4 pieces of ES bushings i had laying around
PR4 ECU
New In Box:
Headgasket, Intake manifold gasket, exhaust manifold gasket, valve cover gasket kit
Water Pump
Timing Belt w/tensioner pulley
Clutch and Flywheel
PS belt, Alt belt, A/C belt
https://post.craigslist.org/imagepre...f78822143a.jpg
https://post.craigslist.org/imagepre...b36beb1022.jpg
https://post.craigslist.org/imagepre...82e6091b0f.jpg
https://post.craigslist.org/imagepre...9334601fec.jpg
$200 OBO .... WILL NEGOTIATE NEED IT GONE!
Motor burned oil and needs a rebuild. Y7 intake and ecu will complet the conversion from DPFI to MPFI. Taking up garage space, trans is good as well as clutch/flywheel.
d15b2 complete longblock with transmission, axles, shift linkage
d15y7 complete intake manifold
P05 ECU
http://images.craigslist.org/3Ec3Ia3...a4ada61893.jpg
http://images.craigslist.org/3M23L83...3c430a1ee7.jpg
http://images.craigslist.org/3Ka3kb3...4539691f27.jpg
http://images.craigslist.org/3Gb3F33...04f6d1192f.jpg
$70 - P2T ECU from '00 Civic Si
$10 - 91214-PLE-003 B18C Rear Main Seal (new in bag)
Best Offer:
92 Integra Left Headlight - no cracks or broken tabs
92 Integra Right Headlight - no cracks or broken tabs
92 Integra Front seats
92 Integra Rear Seat
PR4 ECU
New In Box:
Water Pump
Clutch and Flywheel
P05 ECU
Best Offer:
Turbo02si
Jul 29, 2012 10:01 PM
