Re: Took my diy alignment setup to the next level...
It only cost me about $60 bucks for a string box setup. Already had a few of the things needed though. Just get a list together and buy everything, it will pay for itself the first time you use it.
Thanks guys.
Originally Posted by 1998GsRIntegra
Looks good dude. Welds are no worse than mine. Can you give any details on it?
I used about 6ft of 1" steel square tube, cut into 6" pieces to make the cross pieces. The long bars are 3/4" Aluminum square tube. Laterals and Verticals are 36", longitudinals are 18". About 24ft total. All of that cost about $20 (2.90/lb for any Al alloy!) at the industrial surplus yard up the road in Sanford. I freaking love that place.
Thumb screws and endcaps for the Al tube came from McMaster-Carr, I spent about $25 on that with shipping. The caps only came in packs of 100, but whatever. I thought I had ordered the screws in 10-24, but when I got them they were 10-32. I wish I had gotten the coarser thread, engagement pressure would be better. You really have to crank on them to get them to stay. Oh well.
Welded the "fingers" onto the end of the Al longitudinal bars to hook over the core support and trunk opening. Plasti-Dipped the ends so that they don't scratch things up.
The conduit I already had from my previous setup. It has sets of grooves cut into the ends at 1.5" intervals, equally spaced from the center so I can quickly set it up for pretty much any car.
A little primer and paint on the steel parts, and it's all done. Cant wait to try it out this weekend, being able to jack up the car to adjust and not have to resquare is going to be awesome.
Yeah I could have done a little cheaper, but I really have everything I need now to do it legit, and it looks nice to boot. I'll post up some pics tomorrow of my toe board and camber gauge.
Have you done the vinyl tile/axle grease slip plates? Works awesome!
It's not about paying for alignments to me. I just prefer to do things myself. I know how to do it, I used to be great at it when I had access to a rack.
Last time I paid for an alignment, they tried to bang me for 1/2 hour per corner to adjust the camber and wouldn't warranty it since my car was lowered. 3 months later I noticed some toe wear showing up and went back, and they wouldn't do ****. Been doing my own ever since. I have my own specs anyway, I don't feel like haggling with a service writer to get **** done my way when I'm the one paying.
Originally Posted by Slacker93eg
How much are you guys paying for alignments? I can get one around me for like 60$ lol
Considering buying all the stuff to DIY cost barely more than that, you can also set your specs to whatever you want instead of having some grumpy old man tell you it's within spec. I would say the hour it takes to do is worth it.
Originally Posted by PatrickGSR94
I don't see how you can make accurate adjustments while the suspension is at full droop. What's the actual process for adjustment with that setup?
Measure alignment with tools, jack car up, adjust tie rods/ camber kit, etc, lower car shake and move car so suspension settles, recheck alignment again, and repeat the process until you get close to the values you need
There are many methods though, I haven't seen this thread until now, but I have something similar. Nice thread! For turn tables I just got 4 of the 1000 lb lazy susan replacements. The sliders can be fabbed up if need be rather easily as well. This can work too for turn tables - gives you an idea of what I am talking about below.
I use vinyl floor tiles. A pair under each wheel with some grease between them allows me to push the car around easily, even straight sideways, with one hand.
They're 1/8" thick, so I also use them with a water level to level the floor.
Great method that also brings closer to level an inevitably unlevel surface. I've been using plastic grocery bags under the tires which have worked great in the past but don't take it the one step further as you have done.
