NC AGP 1993 Civic Si Hatch (B16/ITR)(A/C-P/S-CC)
Price: $5500obo
The Bad: See Below
The Good: See Below
Been contemplating this for a while. I have taken this from a Bone Stock Hatch.
So here goes:
Suspension
1996 JDM ITR 4x114.3 Conversion
ITR Brakes
EF EX Sedan Master Cylinder (15/16ths IIRC)
Brand New Hawk Pads
Fr Camber Arms
Rr Camber Arms
Function7 Subframe Brace
ITR 23mm Rear Sway Bar
Apex'i Pro N1 Coilovers
98-01 ITR LCA's
Brand New Moog Tie Rod Ends
Brand New Moog Sway Endlinks
All Brand New Moog Balljoints
ITR Strut Bar
Motor:
B16a Long Block (Completely Resealed.)
ITR Crank Pulley
S2 Pro Manifold
ITR TB
4-1 Header
GSR Cams
H22 LMA's
Exedy Stage 2 Clutch
Fidanza Flywheel
ES Shift Bushings
Bwr Cam Seal
4.4 ITR Trans (W/ Vin)
Innovative Mounts
Interior:
Del Sol Seats (Green Stripe)
All factory including original Si Cluster.
Sony Deck. Bluetooth, Aux, USB
Overall 8.5/10
Exterior:
CF Duckbill
OEM Si Lip
It has AC/PS/CC as well. All in working order.
No CEL's.
I WILL ONLY ACCEPT CASH. NO CASHIERS CHECKS, NO PERSONAL CHECKS, NO IOU'S, NO USED GUM, NO GIRLFRIENDS (UNLESS THEY ARE HOTT AND CANT SPEAK ENGLISH), AND NO TIRE KICKERS.
Bad:
Needs alittle body work. Few dents and dings. Paint is in pretty solid shape. Just buffed it this past weekend. Has 2 small rust holes on the left rear quarter panel. Not through and through yet and still covered by paint.
Si Door panel fabric is coming untucked. Wasnt a big deal since I was thinking about going EX Doors.
Prior to the Del Sol Seats.
Most everything is documented here:
https://honda-tech.com/forums/appearance-build-threads-122/rd-2-93si-build-3122507/
Price: $5500obo
The Bad: See Below
The Good: See Below
So here goes:
Suspension
ITR Brakes
Brand New Hawk Pads
Fr Camber Arms
Rr Camber Arms
98-01 ITR LCA's
ITR Strut Bar
Motor:
ITR Crank Pulley
S2 Pro Manifold
ITR TB
4-1 Header
GSR Cams
H22 LMA's
Fidanza Flywheel
ES Shift Bushings
Bwr Cam Seal
Innovative Mounts
Interior:
Overall 8.5/10
Exterior:
CF Duckbill
OEM Si Lip
No CEL's.
Bad:
Wow, someone that does the a swap the right way? This is about as rare as it gets. BUMP to you, and well done. If only 99% of the other people that swap cars knew how to do it this way.
I am interested in this car. I see the hood has been replaced. Any signs of front end damage to the core support or inner fenders? Do you have the OE front seats?
Yes, I did the swap. The build thread is on here somewhere. It would have stayed Single Jingle if I couldnt have kept the amenities. My little girl rides in this every day, so a/c is a must.
Thanks.
Thank You.
this thing is nice! selling my car this weekend and will be checking back with this thread to see if still for sale! great job on the swap!
I would pick this up if I weren't closing on a house on the 29th. If it is around after that I will bring it to my wifes attention. Good Luck anyways.
Fayetteville, NC. Can meet though if interested.
In all honesty, I dont know. It appears to be oem as the hinges match the hood.
either way thats a sick car. i wonder what it would look like on some 97 accord se rims.
NHswaps13203
Mar 26, 2008 02:29 PM
