1990 crx si k20a2
Old Feb 28, 2013 | 06:50 PM
krex818's Avatar
Default 1990 crx si k20a2
Im using the ktuned adapter with stock temp sensor ...now in traffic its reading above half on the gauge cluster...im using a misimoto rad and fan..fan is wired to be on always..I flushed the system and put on jack stands to prevent air and still the problem ..im wondering if the k series runs hotter than a d or b series and this is normal ...anyone else have this problem ...or any ideas please :-(...it wont get hot sitting running ..
Old Mar 1, 2013 | 05:53 AM
Spug's Avatar
Default Re: 1990 crx si k20a2
Did you actually bleed the cooling system, or did you just assume there's no air in it because you raised the front end?
Old Mar 1, 2013 | 09:11 AM
RuneRavenX's Avatar
+1
Old Mar 1, 2013 | 10:07 AM
v8eatrr's Avatar
Well I know my d16a6 runs at 160 because I just purchased a replacement thermostat and that's what it was rated at
It wouldn't be odd if k's ran hotter
I'm sure the guy didn't do a k swap and doesn't know how to bleed a coolant system.... You have to be pretty dumb to not see the bleeder valve
Old Mar 1, 2013 | 11:40 AM
krex818's Avatar
okay I think I figuerd it out ...ugh omfg now dont laugh ...fml...I wired the fan up backwards...instead of blowing air to the block it was sucking it in lol...ugh duhh lol...
Posted from Honda-tech.com App for Android
acmoc
26
Mar 20, 2015 11:14 AM
Rev2 9K
Honda S2000
Mar 28, 2008 06:41 AM
hondaboyB18C1
Aug 2, 2007 08:52 PM
rbwdriven
Nov 3, 2006 05:55 AM
intekragsr
Nov 11, 2002 05:58 PM
