H22A accord 97, vivration when accelerating 60mph
FIRST OF ALL SORRY FOR MISSPEALLING ENGLISH IN NOT MY FIRS LANGUAGE.
I have a 97 accord with an H22A jdm with m2a4 tranny, im using the accord engine brakets an mounts, exept the driver side mount im using the prelude one. I keep my old cv axles they were new, also im usnig the halfshaft or midshaft or what ever is called, the one for the driver side cv axle, car has been drived with swap 1,380 miles, but I never drived to 60mph the reaso is cause when I try to get to 60mph the steering wheel starts to shake or vibrate, then stops then shakes then stops then shakes so and so, one time I drove it like that like for a week, and I check the suspension cause the vivration got worse, well the bolts, where lossed, I tigth them back on but make the same thing, after some time the bolts get lossed again and again, cause of vivration, I change the tires brand new and still makes the same, what can cause the car tho shake like that, am I using the wrong mounts and brakets? any suggestions or comments?
That's alright, what is you first language then?
Your tires must be out of balance, take them to be balanced. If that doesn't fix them then maybe you are out of alignment.
I think I need an alignment, the tires where balanced before installing them, also when I did the swap, I took almoust everything off, in the suspension.
Try rotating your tires! Mine did the exact same thing because of uneven wear on the tires, fronts go back, back tires X and get moved up.
zanderclause
Apr 18, 2007 10:00 PM
