itr or skunk 2 valves
so i have my car all apart and its time to put the valves in should i use skunk 2 high compression valves since im running stage skunk 2 cams and valves springs and retainers, are they benfits from using these valves?will i see more power?
im running stock bottem end and i know the more compression the more the cams perform, any answer will be helpful thanks
oh the engine is b18c type r 1997
As far as i know Flow-wise only Ferrea come close to the Stock ITR's. If you want to increase compression just use a thinner HG I dont think you'll have Clearance problems unless you already excessively milled your head.
thumper64
Jun 20, 2009 06:40 AM
Drew17th
Nov 9, 2006 02:04 PM
