Suspension & Brakes Theory, alignment, spring rates....
Suspension Noob- Educate me!
Old Feb 28, 2013 | 06:23 AM
JPerkMr954's Avatar
Default Suspension Noob- Educate me!
I have been looking at a Beaks Lower subframe tiebar for my 00 civic ex. I'm trying to understand the functional purpose of this item for one. And 2, before purchasing, will I need to change anything on my car now to allow this to be installed. I have read that LCAs are purely aesthetics so Im not going to do that. I do plan to lower the car though soon. This may be something I don't need to purchase, I'm trying to understand.
Old Feb 28, 2013 | 06:59 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Suspension Noob- Educate me!
Beaks doesn't do ****. None of those tie bars do.
Old Feb 28, 2013 | 07:34 AM
STOCK_SOHC_DX's Avatar
It adds street cred, looks jdmdopemadsh!tvtakyo¡
Old Feb 28, 2013 | 08:56 AM
98civdx's Avatar
Master Detailer
there is no function.
Old Feb 28, 2013 | 11:21 AM
JPerkMr954's Avatar
Got it.... I wont be buying.... lol
Old Feb 28, 2013 | 01:26 PM
datbumper's Avatar
Just a bling factor. I got them because they look sick. As for LCA's, most people recommend OEM if you are just looking to replace them, or go the even cheaper route and just replace the bushings.
Old Feb 28, 2013 | 05:55 PM
1998GsRIntegra's Avatar
Yep, all those tie bars are for one purpose...Bling.
Most aftermarket LCA's are for bling too with the exception of a spherical bearing setup like something from Kiwi, wicked tuning, or kingpin machine. For the street, just replace the stock worn out bushings with new stock bushings.
Old Mar 7, 2013 | 06:23 AM
JPerkMr954's Avatar
Question - When preparing to lower you car, or just in general for that matter, is there anything that you should replace? I'm thinking tie rods, ball joints, I heard there are upper and lower or something. I'm basically trying to have everything nice and tight... like new... Especially when Im going to lower the car.
Old Mar 7, 2013 | 03:45 PM
No need to replace parts that are still good. Just give all the suspension components a good check over and replace what needs replacing. If bushings are cracked and torn, replace them. If your wheel bearings are loose, replace them, if the ball joints are loose, replace them. Otherwise, just make sure you tighten bushing bolts with the car on the ground so they aren't stressed and get an alignment after you lower it so you don't get toe wear on the inside of your tires.
Old Mar 7, 2013 | 03:48 PM
The Grumpiest
Car is 13 years old. Replace anything you think needs replacing. Maybe even parts you think might NOT need it.
Old Mar 7, 2013 | 04:12 PM
JPerkMr954's Avatar
Any feedback on that energy suspension full bushing set? Like the one for everything? lol
Old Mar 7, 2013 | 04:13 PM
98civdx's Avatar
Master Detailer
It's not a full kit, nor is it worth buying the "Master kit."
Old Mar 7, 2013 | 04:14 PM
Junk
Old Mar 7, 2013 | 04:17 PM
JPerkMr954's Avatar
Ok... not buying.... lol...
Old Mar 7, 2013 | 04:27 PM
If you want a bushing kit that will last more than 2-3 years:
http://www.buyhardrace.com/product/h...gsr-ls_49.html
or
http://picperformance.com/store/scri...?idproduct=233
or
Buy new OEM bushings.
Old Mar 7, 2013 | 04:43 PM
JPerkMr954's Avatar
Thank You for those links!!! I'll have to look into OEM Bushings also.
Old Mar 7, 2013 | 05:00 PM
hunghoang's Avatar
look into getting a rear sway bar. Any sway bay thicker than 20mm then you need a rear subframe braces from ASR.
Old Mar 15, 2013 | 10:32 AM
JPerkMr954's Avatar
I was told those beaks bars are useless....
Old Mar 15, 2013 | 11:09 AM
The Grumpiest
Absolutely they are.
Old Mar 15, 2013 | 08:56 PM
datbumper's Avatar
Beaks bar - Tie bar
Sway bar - Sway bar
Subrame brace - Subframe brace
agb22
Mar 4, 2017 01:44 AM
fromthesun_93
May 6, 2011 06:53 PM
rugimpy
34
Apr 14, 2011 02:39 PM
Black R
Apr 5, 2003 03:08 PM
mackymcg
Jul 9, 2002 01:06 PM
