How do I swap a gauge cluster with a tach into my eg?
I found a gauge cluster at my local junkyard with a tach on it it's in a 95 ex coupe will it bolt right in to my 94 eg? I don't have a tach currently and it's ilegal around here to have a aftermarket tach cause its ubsturction of view so I wanna swap my gauge cluster out. Will it bolt right in and how do I hook the tach up?
You will get far better results posting in the civic forum rather than the Accord one! Unless you're trying to put a 95 EX ACCORD Coupe dash into an EG. Then in that matter, I can't say I've ever seen that. If you needed to run an aftermarket tac you could install one in a pillar pod cluster, or one just laying in front of your original cluster.
Here is a cheap triple gauge pod pillar from Amazon. http://www.amazon.com/GlowShift-92-9.../dp/B000UOAVRI
driftguy2008
Mar 3, 2013 01:56 PM
thegooddoctorceretti
Jun 5, 2007 01:04 PM
