rear sway bar question!!
Old Feb 28, 2013 | 02:41 AM
ribal_gh's Avatar
Default rear sway bar question!!
Hello,
would like to get some details about installing EK9 CTR rear sway bar (guess it is 22mm) on my civic si 00.
Will the stock si endlinks work with the CTR swar bar?
Can i install it on the stock frame?
finally, searched for long time and couldt get an answer ...any body know what it the part number for OEM CTR rear sway bar.
Thanks
Old Feb 28, 2013 | 08:29 AM
ribal_gh's Avatar
Default Re: rear sway bar question!!
any ideas???
Old Feb 28, 2013 | 08:53 AM
98civdx's Avatar
Master Detailer
You need a subframe brace, and stock endlinks will work.
Old Feb 28, 2013 | 10:33 AM
dirty19's Avatar
Ridin Dirty in Cali
Search google using honda-tech in the search string.
Old Feb 28, 2013 | 12:37 PM
Foster12's Avatar
Without searching, why would an EM1 require a subframe brace; if it already has a stock rear anti-sway bar installed? EM1 has 12mm (or 13mm) rear bar, so he is just upgrading.
Not arguing, just looking for clarification.
Josh
Old Feb 28, 2013 | 12:43 PM
H0nda_Crazy's Avatar
I think because the stiffer sway bar transfers stress into the subframe and may cause some deflection, so a brace would help. its not necessary for install but from what ive read, the bigger sway bars need bracing.
Old Feb 28, 2013 | 03:55 PM
98civdx's Avatar
Master Detailer
Josh
The CTR has a factory reinforced subframe, the EM1 does not.
Old Feb 28, 2013 | 04:13 PM
canadaek's Avatar
the em1 is reinforced also . but i'm nut sure if the ctr is thicker
Old Feb 28, 2013 | 04:18 PM
98civdx's Avatar
Master Detailer
If you call nuts a enforcement, sure.
EM1 subframes are the same as the other civics. Non SI's just don't have the nuts inside.
Old Feb 28, 2013 | 04:25 PM
canadaek's Avatar
em1 65750-s02-a90zz ex 65750-s01-a00zz different part #"s is that just for the nut's
Old Feb 28, 2013 | 04:42 PM
98civdx's Avatar
Master Detailer
IIRC, the nuts are welded, so yes.... Other then that they are the same.
Old Feb 28, 2013 | 09:28 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
I generally thought you can go up to 17mm before you need a brace, and even til then, it'll still be sketchy..id run the brace just to be on the safe side.
khronicboy420
Suspension & Brakes
15
Mar 25, 2011 09:56 AM
91EF919
21
Sep 1, 2008 06:13 PM
Midori Green
Feb 12, 2008 11:39 AM
Andrew 825SM
Jul 7, 2003 01:19 PM
