Suspension & Brakes Theory, alignment, spring rates....
DA Integra Inner Tire Wear
Old Feb 27, 2013 | 08:28 AM
Gekko's Avatar
Default DA Integra Inner Tire Wear
I have what I would consider extreme inner tire wear for my moderately lowered DA Integra and wanted to get some opinions as to what could be causing it.
I lowered my car 2-3” on Koni/GC and had it aligned before installing some new wheels and tires (15x7.5 32 offset with 205-50-15 Kuhmo’s). Alignment was set to ~0 toe front and rear with about -2 degrees of camber in the rear and -2.5 or so in the front.
After about 4k miles on the tires I started getting noticeable inner tire wear so I bought and installed some Skunk2 UCA, did the rear washer trick, and had it re-aligned. That alignment was also ~0 toe front and rear and about -1.5 degrees of camber all around.
I’ve now had the tires for about 12k miles and the inner wear still seems too fast.
The pictures below show my tires as they are now. I’ve rotated the tires clockwise twice, once at 5k and again at 10k so each tire has been in its current position for about 2k miles.
Any thoughts? I read on here about people with twice the negative camber I’m running and supposedly no inner wear so I’m confused as to the cause. I’d also like to know how much life I’ve got left on these tires due to the inner wear. I replaced my RTA bushings this past week and had it re-aligned and they called me wanting to sell me tires due to the “dangerously” worn tires.
Old Feb 27, 2013 | 10:43 PM
92civiceg9gsr's Avatar
Default Re: DA Integra Inner Tire Wear
Rear toe links could have worn bushings allowing toe change while driving.
Aztec-EJ1
Jul 1, 2014 09:57 PM
GSRkrod
Honda S2000
17
Oct 13, 2009 05:15 PM
Kyles ej1
Jan 8, 2005 04:07 PM
itr1235
Jul 12, 2003 03:24 AM
The_PissingDog_Crx
Apr 5, 2003 09:54 AM
