Code 15? still running
Old Feb 27, 2013 | 07:38 AM
CRX-CHACE's Avatar
Icon2 Code 15? still running
So I finally got my cluster working and everything but the crx is throwing code 15? Could this be because a bad crimp connection? I know there are some sketchy crimps going from the blue plug off the harness to the wire that plugs into the dizzy (the two wire plug) if this is the reason or could be the reason I was wondering if it would be better to solder or maybe a better way to crimp? AS ALWAYS, THANKS HONDA-TECH!
Old Feb 27, 2013 | 08:08 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Code 15? still running
Solder>Crimp, but as long as the connection is made it should work. Having said that, what is code 15? Have you looked it up? Have you made any attempt to verify if that is a valid error code?
Old Feb 27, 2013 | 08:13 AM
CRX-CHACE's Avatar
No spark code, but it starts easier than ever
Old Feb 27, 2013 | 08:15 AM
24TEN's Avatar
PHANTOM MENACE
That's odd... Wish I could point you in the right direction. Have you looked up the procedure to trouble shoot this in the FSM (that is if you have access to one)?
Old Feb 27, 2013 | 03:20 PM
CRX-CHACE's Avatar
It stopped throwing the code randomly
Old Feb 27, 2013 | 04:57 PM
24TEN's Avatar
PHANTOM MENACE
Did you reset the ECU? If not it's still stored.
DESTROYDCB7
Jul 10, 2011 07:13 AM
jmeyer99
Aug 2, 2007 10:18 PM
BeezInACan
Oct 20, 2006 08:00 AM
