94 civic LX delay start
Old Feb 26, 2013 | 06:08 PM
allinwitad's Avatar
Default 94 civic LX delay start
My civic will not start when i first get into my car. I must turn the key to the on (II) position until the check engine light goes off then the car will start. This can take anywhere from 5 sec. to 30 or 40 and usually only happens when the car hasn't been running for a few hours. My friend has a Del Sol with the same issue and we can't figure it out. Any ideas?
Old Feb 26, 2013 | 06:32 PM
Yesidriveacivic's Avatar
Default Re: 94 civic LX delay start
Did you try lifting the clutch pedal up and pushing it back down again? It doesn't sound like that's it, but mine does something similiar to that with the waiting for it to start....
Old Feb 26, 2013 | 07:56 PM
Former User's Avatar
This is usually caused by a bad ECU. But before you replace it, clean and tighten the G101 ground on the thermostat housing and put new fuses into slots #31 (hood box) and #24 (dash box).
Old Feb 26, 2013 | 08:32 PM
allinwitad's Avatar
Thanks Ron I'll check those. If it is the ECU should I replace it? The car is starting, just delayed. Will the problem get progressively worse? Is it a tough job?
Old Feb 26, 2013 | 08:33 PM
If G101 and the fuses are fine, buy a replacement ECU. Otherwise, you may get stranded.
BSG
87
May 13, 2013 09:12 AM
underdog217
Jul 23, 2012 05:59 PM
ncnative
10
Dec 28, 2004 07:27 PM
Maddox
Jan 29, 2004 04:01 PM
