Compression too high on h23a
Old Feb 26, 2013 | 05:30 PM
Shanemoore9's Avatar
Default Compression too high on h23a
Hello I have an 02 accord coupe engine swapped with the h23a dohc vtec jdm motor with a stock comp ratio of 10.6:1. I was checking the compression because in turboing in the very near future. On 4 cranks the gauge reads 180psi which is pretty good. But if I keep cranking until the needle stops moving it reads 210? Is my compression super high or is the 180 the compression I should follow? Thanks for any replies.
Old Feb 26, 2013 | 05:35 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Compression too high on h23a
2 different kind of compression numbers chief.
Old Feb 27, 2013 | 03:19 AM
Alright that's what I assumed. So what do these 2 different numbers mean?
Old Feb 27, 2013 | 05:17 AM
doood's Avatar
been there done that
it means your engine is pretty damn healthy
Old Feb 27, 2013 | 06:28 AM
Thank God. i thought those numbers seemed too high but I guess not.
Old Feb 27, 2013 | 06:42 AM
The Grumpiest
That's perfection right there.
Old Feb 27, 2013 | 07:13 AM
snobordboy's Avatar
Moderator
Yeah 210 is a decent number for that engine, especially if they are all within a few psi of each other. My H23 built with the slightly longer H23A1 rods, and JDM H22 pistons only makes 230-235 on my tester, and calculators show it to be an 11.6:1 engine.
Old Feb 27, 2013 | 07:52 AM
h22-eg-hatch's Avatar
210 is good compression. . If u boost it. Just mke sure to have a good tune
My bone stock h22a4 made 300 hp on 5.5 psi on a( 50 cold / .63 hot )
full boost by 2k rpm. **** ripped.!!! only prob with turbo n high comp is timing/ detonation. The motor Lasted a while before she gave ... Make sure u have a good tune/tuner
Having 200hp / 200 tq at 2200 rpm. Lol. Imagine the feeling. Haha.
Deffinately fun.
Old Feb 27, 2013 | 09:32 AM
Any way I can lower the compression or make it last longer on boost? I'm looking at bone stock 6-8 psi for a while till I can build it more. Any suggestions for making it last? Besides a good tune
Old Feb 27, 2013 | 09:39 AM
What setup did you have to get those numbers at 2200rpm??
doug25427
Honda Civic (2001 - 2005)
Dec 18, 2018 02:50 PM
range hadies
Mar 25, 2012 12:18 PM
huge230
Oct 2, 2005 10:40 AM
turbotime
Oct 1, 2005 08:46 AM
builtprelude
Jan 22, 2004 10:49 PM
