Transmission grinds
I have a stock 97civic with a stock d16 and third and fifth gear grind once I rev past 4000 rpm.
I changed my transmission fluid but that did not work. So what can be the cause of the grinding?
Worn 5th gear sleeve most likely, but you wont know for sure until you take it apart. Could be a worn sleeve, hub, gear or some some combination of all 3, along with a worn 5th gear synchro.
HondaRcB
Nov 24, 2006 11:41 AM
Rod.
Nov 7, 2004 01:13 AM
Tyson
May 30, 2004 06:18 PM
